What would cause exhaust noise to appear its coming from before my 5th gen Muffler?
Old Aug 9, 2010 | 08:17 AM
shadyonedeath's Avatar
Setup:
Warpspeed Y pipe -->5th gen cat-->2.5" mandrel bend b Pipe w/Magnaflow 22" Resonator-->5th gen Muffler
Problem is, it sound like the magnaflow makes all the noise under the car instead of spitting it out the muffler. Like there's a huge drone when rolling to a stop sign and lightly stepping on the gas to take off. Its all brrrrrrrrrrrr and little "Go".
any idea's? Here's a clip of the rear, notice little noise is coming out from the muffler, most of it is from under the car. Is this normal for having a magnaflow resonator? Is it mis-matched with the stock 5th gen muffler?
http://www.youtube.com/watch?v=B-0wvw6e5bo
Old Aug 9, 2010 | 08:47 AM
Check for a leak maybe?
Old Aug 11, 2010 | 06:38 PM
Racing Nissans's Avatar
Start cold car. SET PARKING BRAKE! Reach under car and feel around muffler and pipes to see if it is leaking...sounds like it is.
Old Aug 11, 2010 | 10:09 PM
fck man, i think its the y pipe again. What else can I use on the y pipe to Manifold end as far as the crush ring gaskets. The ones i bought at autozone don't seem to seal high enough, they fit, but the gasket just sinks in. Are autozone rings thinner than OEM oneS?
Is there a metal gasket I can use on that flange?
Old Aug 12, 2010 | 09:31 AM
Mad-MAX_SE's Avatar
Still kickin'
when you say the "gasket just sinks in" what do you mean?
Old Aug 12, 2010 | 04:48 PM
it sits flush with the flange...as in, it BARELY shows any sign of mating contact with the manifold flange.
Old Aug 12, 2010 | 09:54 PM
Just get OEM crush ring gaskets. They're not expensive.
Hondarydr
Dec 30, 2024 06:15 PM
Finkle
Sep 27, 2015 09:53 PM
erictown
Aug 20, 2015 08:01 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
