quick question about audi style led strips
Old Aug 18, 2010 | 08:27 PM
ivorton23's Avatar
I just got my led strips off ebay. i want to put them below the headlights and set them up so they come on with the park lights. does anyone know the color of the park light wire and where it's at? also the led strip has one clear wire and another clear wire with a red stripe on it. anyone have an idea which one is for ground? thanks.
Old Aug 18, 2010 | 08:58 PM
Doomi30's Avatar
what would be great is a write up for this. i've been wanting to do this but have no clue how or where to start. im fairly wiring inept but good at following directions! haha if you figure it out you should def do a lil right up with some pics if you have the time or even feel like it. i would be very grateful. good luck with the project!
Old Aug 18, 2010 | 09:25 PM
Just tap into the corner light harness. Use a test light to figure out which wire is positive.
On the LED strips, positive is probably the clear wire with the red stripe, ground is clear.
Old Aug 19, 2010 | 05:31 AM
ajm8127's Avatar
Use a wiretap to make the connections (use the ones for 22-18 awg)
And use plenty of electrical tape around the connection to seal it up.
Old Aug 19, 2010 | 09:12 AM
njmaxseltd's Avatar
Old Aug 19, 2010 | 11:40 AM
ivorton23's Avatar
so now i got my other set of leds to put under the dash. where do i connect those wires to??? i'll try n post pics of the leds.
Old Aug 19, 2010 | 11:48 AM
ajm8127's Avatar
Use the wires for the parking lamps in the steering column.
Old Aug 19, 2010 | 07:02 PM
ivorton23's Avatar
well the good news is i figured it out and got one led strip on and working. the bad news is i cut the other strip too short and ruined it. is there a way to put it bad together and make it work or am i screwed? now i have one strip on the car and it'll look retarded like that.
Old Aug 19, 2010 | 07:03 PM
ajm8127's Avatar
Take some pictures of the cut strip.
Old Aug 19, 2010 | 07:46 PM
ivorton23's Avatar
this is the led strip i put on
Old Aug 19, 2010 | 07:52 PM
ivorton23's Avatar
this is the strip that i ruined. i was trying to cut to the length of the headlight.
Old Aug 19, 2010 | 10:46 PM
I wrapped the ends of the wires around the cig. lighter plug. Worked fine for me.
BTW, the strip looks good, but I think you should change the amber corners to white. It would look better.
Old Aug 20, 2010 | 04:43 AM
ajm8127's Avatar
I think it would be next to impossible to repair that. The flexible circuit board does not lend itself well to soldering.
Old Aug 20, 2010 | 11:19 AM
wirelessdude04's Avatar
not bad doesnt look bad at all
Old Aug 20, 2010 | 11:59 AM
ivorton23's Avatar
how do i get the cigarette lighter out? or can i tap a park light wire inside the car? where is that at and what color is it?
Old Aug 20, 2010 | 01:56 PM
It's extremely easy, you can pop it out with a small screwdriver. Once you pop it out, you'll see that it unplugs. Going into the harness there are 2 wires, one that's black and one thats black and has either a red or orange tracer. Follow the wires to where they plug and you'll figure out which plugs are positive or negative. Then wrap the wire around the plug, and plug it back into the harness. Turn your key to the ON position and see if they turn on.
That's what I did and I haven't had any problems.
Old Aug 20, 2010 | 04:00 PM
najee1062's Avatar
I've seen these set ups around in person and me personally I don't like it to well for the 4th headlight housing being place on the outside. I know some love the Audi LED running lights and as I do but this is a cheap way for that look. No offense to you guy it's your car and if you like it that's all that counts.
Love the interior lights and the color is great... specially if you're using them while driving. Love it.
Old Aug 20, 2010 | 04:08 PM
Decimus Meridias's Avatar
looks about like mine (interior). Good Job!
Old Aug 20, 2010 | 04:14 PM
ivorton23's Avatar
Well I finally got it! i just connected the wires to my taillight fuse and got ground from under the dash and shes working great. i'll take some pics. my next project will be the gauge cluster!!
@najee1062 i know its the cheap way but its what i can afford at the moment...know what i'm saying??!!....i think it looks great anyway. it'll have to do until u give me money the do it the expensive way(haha jus kiddin)...or until i get a raise at my job.
Old Aug 20, 2010 | 04:32 PM
najee1062's Avatar
I feel your pain... I'm in the same sinking boat LOL. I am researching some alternatives with that set up and trying to find the cheapest way possible but integrated it within the all in one housing. I've seen one other set up like that and I believe it will cost just as much but only for those who have to all in one housing. Also I will be doing custom LED Tails. But again I hope I didn't offend.... I had been considering that set up also at one time....
Old Aug 20, 2010 | 05:22 PM
ivorton23's Avatar
yeah i wanted to do led tails to but i dont know if i can do it with 96 taillights. i'm thinking about converting to 97 trunk and getting those skyline style led tails. i just love those ones. right now i need to replace my entire exhaust system cuz its all rusted out. i took it to have my new fireball muffler welded on but couldn't cuz its to rotted to be welded on to. so i gotta come with at least 500 bucks to replace that!!!!
Old Aug 20, 2010 | 07:42 PM
ivorton23's Avatar
so this is the finished product. looks much better and brighter in person. next is the gauges!
Old Aug 20, 2010 | 09:45 PM
najee1062's Avatar
converting to 97 truck and get some clear you can do custom LED tails if you have the time... but I love those skyline LED's too. Just to many others have them. I trying to do something different.
Old Aug 20, 2010 | 09:46 PM
najee1062's Avatar
Love it nice job!!!
Old Aug 21, 2010 | 07:27 PM
ivorton23's Avatar
thanks...i ordered another led strip to put on the right headlight..should get it by middle of the week.
Old Aug 21, 2010 | 07:34 PM
Atimaxx's Avatar
I hope they are more reliable then the Audi ones. I've seen so many newer Audis with one LED strip turned on and the other off and it's pretty weird for such a "reliable car" for those to be faulty.
Old Aug 21, 2010 | 07:44 PM
najee1062's Avatar
Right... my neighbor has an audi suv and a few of his LED's are blown out. They told him they would have to install the whole light housing and he would have to order due to a back log or orders and his been waiting 3 months now. They are sooner or later going have them recalled
Nice look on them though but they have to get those glitches out....
Old Aug 21, 2010 | 10:30 PM
5150pa's Avatar
God I love blue interior lights...
Old Aug 22, 2010 | 02:03 PM
ivorton23's Avatar
word...cant wait to make my gauges blue...that'll be swweeetttt!!
Old Aug 28, 2010 | 08:35 PM
ivorton23's Avatar
so here's the finished result..what yall think?
Old Aug 28, 2010 | 10:18 PM
cartman854's Avatar
Looks good.
Old Aug 30, 2010 | 04:38 PM
KAZEN Inc.'s Avatar
Hello~I already using the LED under the dash.
I connected the wire with the dome light connection.
It working so good.
If you want to see it, just let me know. I'll upload the pictures.
Old Aug 30, 2010 | 04:51 PM
TheArtist's Avatar
i really like the strips and the orange you have going on, ive always loved that look!!
i really do hate that people hook these up as intended for running lights like the audi but then keep them on with their headlights. it looks funky and bad to me. not trying to bash on you i just see it all the time on hondas and what not. its not that hard to hook up a switch to control when the lights come on or off.
Old Aug 30, 2010 | 06:04 PM
96MaXiclean's Avatar
got cheese? lol
Old Aug 31, 2010 | 04:50 PM
Akiyukio's Avatar
The lights look good. If you could some how block the light from reflecting back in to the headlight, that might make it look even better in my opinion.
Also liking the under-dash lights. Mine are set up so that when I open the doors, they would come on and shine bright white. More of a function then form thing for me.
You might want to consider another LED that just shines down on the dash. I have a LED mounted behind my review mirror that just shines VERY FAINTLY down on the dash and illuminates it. Similar to a Mercedes Benz or the New 2010 Maxima "Mood Lights" but the same or dimmer.
While we're on the subject of LED lights and led strips, I was wondering where would be a good position to place turn signal LEDs on the side. Sorry if I'm thread jacking.
Here is my position: Our cars can signal well front and back, but when people are on our sides, they have no way to tell we are signaling to go into their lane. So, I was considering adding LED strips on the side of the car somewhere so I could get that type of functionality. I've considered a lot of ideas, but I'm still kinda "ehh" on where I should place them and not mess up the overall design of the car. I also want them in a place that would not fall off easily, nor do I want them in a place that impedes safety.
I've considered:
- On my mirrors (Like some Ford cars) but that blocks some of my rear views.
- Around the outside of the mirror shell (Like some Audis) but this design is too exposed.
- On the triangular mirror mount, (next to the window there is a thin and small triangular area) but this limits the amount of "signal area" that the light has and is some what exposed
- On my mud flaps, but that is just too low to be effective, and very exposed
- Inside the car, however I don't want to compromise the beauty of the interior with a random light.
Old Sep 1, 2010 | 07:21 AM
queenambeach's Avatar
Those LEDs are cheap and burn out quickly. I hope yours last though.
Old Sep 1, 2010 | 07:22 AM
I've considered:
What wire(s) did you tap into to have your interior LEDs come with when the door is open?
Old Sep 1, 2010 | 07:51 AM
Goomz's Avatar
just tap into the door switch wires i think its the red with a white stripe iirc. its a neg trigger.
Old Sep 1, 2010 | 12:15 PM
ivorton23's Avatar
@ queenambeach....yeah i hope it lasts long too. im the only person in this town that has leds like these. everyone looks at them when i have them on at night. i especially love the ones under the dash....i have to extra led strips lying around. am trying to figure where to put them...any suggestions??
@akiyukio...why not just get those m3-style led side mirrors....that would solve that issue.
Old Sep 1, 2010 | 12:40 PM
Do you have your LEDs inside or outside the headlights? I have some inside my I30 headlights, but I use a different kind. The ones like your I had over my license plates in the back and they blow out after like 2 days. Installed some others in my Maxima headlights and they blew out after like 45 minutes...
