Strange O2 issue
Old Aug 28, 2010 | 08:07 PM
hornepirate's Avatar
Strange O2 issue
about a week ago i got a code for both upstream O2 sensors (P0130 and P0150). I order a bosch OE sensor for bank 2 and got an oem bank one sensor from a reliable seller on the org.
Replaced both O2 sensors and reset the ecu Via OBD2 scanner. Went for a drive and the codes still appeared for both banks. Reset via Unplugging the battery. Codes still appeared.
The O2 sensor fuse is in good btw.
Any suggestions:?
Old Aug 28, 2010 | 09:53 PM
asand1's Avatar
Check the how to stickies and reset with the screwdriver.
Old Aug 29, 2010 | 02:43 AM
ColombianMax's Avatar
My buddy had the same issue but it was the scanner he used, it was rather old. Is there a way you can try with a different scanner?
Old Aug 29, 2010 | 05:56 AM
i might be able to try a different scanner and i know how to manually reset the ecu...ill probably try that.
Old Aug 29, 2010 | 05:57 AM
if anyone else has other suggestions just let me know
Old Aug 30, 2010 | 02:22 PM
4thGenRyan's Avatar
Hey guys, first post after lurking for years, hope it helps. I just did a swap out of all three O2s and had an issue much like yours. I first tried the manual method of reseting the code but the light would always come back with in one or two test starts. I was able to get a code scanner and clear it. Again it would pop back on with one or two test starts.
Upon close inspection of the socket on the end of the o2 sensor I noticed that the three little prongs inside were slightly bent to the left and were not going into the corresponding three holes in the female socket. I gently moved them to a straighter angle and plugged it back in. Read the code, cleared the code and have been driving for 80 some odd miles without it returning.
Just something to check.
Old Aug 31, 2010 | 03:59 PM
eddie982's Avatar
very nice observation! I'll change out my o2's this week, now i know what to look out for.
Old Aug 31, 2010 | 06:12 PM
explain a bit further what you mean by the three little prongs inside?
Old Sep 1, 2010 | 01:38 AM
Prongs/Pins that physically make the connection inside the harness. The pins were bent so when he plugged the o2 sensor harness, it clipped together but contact was not made due to bent pins/prongs. Hope that explains more about the prongs inside
Old Sep 1, 2010 | 06:24 AM
ah okay yeah ill check it today...found out i had an exhaust leak from the header to y pipe flange so picked up some gaskets and maybe thatll stop the O2s from getting incorrect readings...but the funny thing is the car isnt running in open loop like it would normally with bad O2s... My Can OBD2 said my car is running in closed loop...
Old Sep 1, 2010 | 11:05 AM
Changed out my ypipe gaskets and manually reset the ecu...still having issues with the O2 codes coming on and i checked all the connections and they are all good
Old Sep 1, 2010 | 01:26 PM
Are those the ONLY two codes showing up? Absolutely nothing else?
Old Sep 1, 2010 | 07:22 PM
yeah only those two codes nothing else...
Old Sep 11, 2010 | 03:18 AM
been about 2 more weeks of driving and the O2 codes still come up. but my MPG seems un affected if that matter at all.
still completely stumped as to my issue at hand here
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
