Car revs to 1.5k then drops to 1k. TPS issue?
Old Aug 28, 2010 | 10:21 PM
OC_Nooby's Avatar
Hey
So I noticed this happening to my car the first time I took it to the 1/4 mile. Regardless of where it happened, if I was to drive the car for 5 minutes then stop at an intersection or wherever the car would stay at 1.5k rpm then seconds later would drop to 1k rpm (where I have set screw). Now sometimes it doesn't do it and other times it does. My idle is great. It just pisses me off that the car will randomly rev as I come close to a stop or if I drive and hold the clutch/neutral on the highway.
Could my TPS be at fault? I'm using a really old one which might cause the issue (probably has 260 xxx km's on it). If im correct I used my 4th gen TPS on the 00vi Swap. Not sure I'm correct though, been a while since I did the initial 00vi purchase/prep work.
Car still drives well and has no issue as I'm on the gas/cruising, just when I'm at a light or place it in neutral while driving.
Old Aug 29, 2010 | 01:58 PM
OC_Nooby's Avatar
Anyone?
Old Aug 29, 2010 | 02:00 PM
Doomztown's Avatar
try resetting the ECU by unplugging the battery for a bit and see if that helps.
Old Aug 29, 2010 | 02:21 PM
Trini Boom's Avatar
Originally Posted by OC_Nooby
Anyone?
Did you have your A/C on at that time??
Old Aug 29, 2010 | 02:31 PM
sgtboehn's Avatar
Ive been having the same problem, I just installed my new TPS today and cleared the codes, fired the car up and no change. Im gonna drive it for a few days and see if anything changes.
I was also told that the problem could be the transmission, the neutral safety switch (plug) could be faulty.
And like you said somedays it will do it and other days it wont. Is your CEL on? I threw the codes P0120 TPS, and P0173 Fuel Bank Trim 2.
My idle always jumps when going into gear, at least 1500 rpms or more.
Have you tested your TPS yet?
Old Aug 29, 2010 | 05:13 PM
OC_Nooby's Avatar
No this did not help.
Nope
I have no codes pertaining to the TPS, I have not tested out the TPS. The car was fine before and this happened out of the blue. I'll measure the TPS.
Old Oct 16, 2010 | 03:35 AM
Sinturion's Avatar
N00blargh
Sorry to bump up an old thread - I have the exact same problem for quite some time now - ever since I did my manual conversion (using AT ECU).
I haven't wired up the neutral/clutch switch - I'm starting to think that sgtboehn might be onto something.
Does anyone have any more info on this? does the ECU take into account if the car is in neutral/clutch engaged and use that information to control the IACV?
Old Oct 16, 2010 | 05:59 AM
99BlackMaxMS's Avatar
My car will do this when its colder out from time to time...not really sure what it is doing but I feel as though I have messed with enough things (IACV, TPS, etc) to try and get the car to idle correctly. I can live with it when it occasionally idles around 1200-1300 before dropping back down to normal when its cold out.
Old Oct 16, 2010 | 09:31 AM
aackshun's Avatar
Same problem here, I just assumed that it's a vacuum leak and not really worried about it.
Old Oct 16, 2010 | 11:07 AM
supachin's Avatar
i got that same issue!! seems like tons of these 4th gens have it. there's a thread on the org, this dude changed EVERYTHING in the car and he still have the problem. i guess we're just gonna have to live with it. but i'm going to be an *** and try to fix it anyway. i bought an IACV from maxfever today, gonna swap that out later today and see how that goes.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
schmellyfart
Sep 25, 2015 04:47 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
doobadoo
Aug 15, 2015 06:43 PM
