Inner tie rods
Inner tie rods
I'm going to be replacing inner tie rods soon and I understand the basics, however I could use some tips on the "locking plates". The manual says they are
"clinched" in place to the rack. How do you unclinch them? How do clinch the
new ones? Also in looking at various inner tie rods -some come with factory
style lock plates which engage all 4 flats of the tie rod, while others look like
a flat washer with just 2 tabs apparently to lock to the rack-but I dont see
how they would lock to the flats of the tie rod . Anybody have experience
with these??
with these??
When I did inner tie rods on a Pontiac Fiero, the plates fit over a square raised portion on the rack. The plates were then bent over the flat spot on the tie rod. the plate looked like a Chinese coin with the square hole.
When I looked at the plate there were 2 little dimples visible from clinching. They'd be easy to miss if one wasn't looking for them.
I didn't bother trying to clinch the new plate. If you feel compelled to do it then a small punch or scratch awl would do the job. Maybe I'll go back and do them if I get bored over the weekend.
I used an air hammer/air chisel and hit the bigger portion of the inner tierod to go counter clockwise. Much easier than tried to loosen it with any other tool IMHO. To tighten I went by hand until it was hard, then I used the inner tierod tool or some channel-locks. Dont forget to use thread lock
James92SE
142
01-02-2024 09:23 AM
knight_yyz
11-01-2015 01:34 PM
