Crank Pulley failures - how many miles?
Old Aug 30, 2010 | 08:27 AM
cdmapro's Avatar
seeing all the posts about broken crank pulleys is worrisome. makes me think about proactively replacing mine before it goes. 99 w/ 155k mi.
for those who have had them break - at what mileage are they breaking?
also dreading the figgin water pump.
Old Aug 30, 2010 | 10:04 AM
cashoit's Avatar
A crank pulley is gonna make some noise before it goes. I wdnt worry about it.
Unless u wanna jus replace it...im all for preventative maintenacne
Old Aug 30, 2010 | 10:11 AM
plugeye's Avatar
99 max with 226k. i heard something not right one day & thought i saw the compressor wobbling. no problem, bypassed the compressor. then right after noticed it was the crank pulley wobbling. so i bought a used crank pulley from an inmate on here. it sat on the bench for maybe a week. noticed a noise only on start-up the last 3-4 times. then went to start it & the pulley snapped off.
so in my case, i heard the noise & shortly after it failed.
Old Aug 30, 2010 | 01:11 PM
cdmapro's Avatar
anyone have a sound byte of the noise? i do have a chirping sound coming from the general area. can't tell if it's the AC compressor, idler pulley, or what.
Old Aug 30, 2010 | 01:41 PM
ajm8127's Avatar
Just do a visual inspection. If the rubber is starting to separate from the metal, replace the pulley as a preventative measure.
Old Aug 30, 2010 | 01:50 PM
99BlackMaxMS's Avatar
159K is when mine went (like 2 weeks ago, lol).
Heard an awful noise one day coming from the pulleys, got down and looked and was able to move the crank pulley with my hand from side to side, so I got a new one and swapped it in. Problem solved.
Old Aug 30, 2010 | 04:35 PM
defiance's Avatar
Are there instructions somewhere on here for installing these pulleys ?
Im pretty sure its not just an unbolt pulley - put new one on type of deal.
Old Aug 30, 2010 | 04:52 PM
Italianjoe1's Avatar
It is unbolt and replace, but it's on there pretty tight and needs to be re-torqued properly.
I'm suprised these cars use a two-piece pulley like that. I just pulled a motor on a '96 and the crank pulley was completely separated. Had about 185K on the motor. It also chewed up the A/C comp pulley, not sure which went first though.
Old Aug 30, 2010 | 07:44 PM
The hardest part is getting the bolt off of the main crank pulley, other than that its a piece of cake. Without air tools and/or a lift, it can be difficult though, which is why I had help doing it.
Old Aug 30, 2010 | 08:02 PM
99fivespd's Avatar
127k - no warning - just ordered Unorthodox w belts for 230 on Ebay - dealer wanted 358.
Old Aug 30, 2010 | 08:32 PM
JwaxMax99's Avatar
190K.
Old Aug 30, 2010 | 09:12 PM
I did it with the engine on a stand, and it took a jack handle on the breaker bar to get it off.
Old Aug 31, 2010 | 06:00 AM
Trini Boom's Avatar
I remembered my stepfather creating his own way to get that bolt off. What he did was cut off the tip of a spark plug and welded a 2" long iron to it and was just as thick to fit through the spark plug hole. Once he screwed it in into cylinder 1 and turned the crank until the cylinder head touched it, he then took a breaker bar with the handle from a 2 ton jack and broke it free without problems.
Opposite way used to tighten it back also...I wonder if something like this is sold now...if not, I gotta try and find him to get one made for myself...
Old Aug 31, 2010 | 06:10 AM
plugeye's Avatar
sounds hazardous
easy way was breaker bar wedged against the chassis, wife bump the starter.
Old Aug 31, 2010 | 06:17 AM
Trini Boom's Avatar
Originally Posted by plugeye
sounds hazardous
Nothing hazardous about it... he has done this to many cars he has worked on and not a single problem. He was a mechanic and retired..
Old Aug 31, 2010 | 08:24 AM
dgoodhue's Avatar
The make piston stops which are similar to what your talking about. I know who did something like that with a piston stop. I later had the cylinder head off the motor, their was an indent in the piston. It wasn't bad, but I wouldn't do or recommend it.
Old Aug 31, 2010 | 08:29 AM
dgoodhue's Avatar
sounds hazardous
If the breaker bar slips it could cause some damage or hurt someone.
Old Aug 31, 2010 | 09:22 AM
plugeye's Avatar
you aint kiddin
the 1st attempt i tried holding it, haha put a nice dent in the oil filter
Old Aug 31, 2010 | 09:46 AM
dgeesaman's Avatar
Maintenance Monster
You can also jam the flywheel or just use an impact wrench to remove the bolt.
Mine went at 217k and I believe it was really caused by an oil leak in the area that got on the rubber element.
I've yet to replace mine, it's getting to the top of my list.
Dave
Old Aug 31, 2010 | 10:44 AM
PGB25's Avatar
160k
plugeye's Avatar
amen. holed piston/ bent rod/ main bearing flattened...
a whole host of nasties with all that starter torque
Old Aug 31, 2010 | 01:42 PM
You can also put the car in gear and hold the brakes... much safer than trying to wedge the piston or something crazy like that.
Old Sep 1, 2010 | 09:33 AM
TravisCadello's Avatar
i got 298k miles and im pretty sure mines original.
i inspect it its dirty but not broken up.
Old Sep 1, 2010 | 10:56 AM
Sandm849's Avatar
140k and started chirping before it totally came apart.
Old Sep 1, 2010 | 11:44 AM
Trini Boom's Avatar
What kind of chirping?? Is it the same as a worn accessory belt??
Old Sep 7, 2010 | 07:37 PM
Dave Holmes's Avatar
Both of my VQ30's ('97 Maxima & '00 I30) are right at 140,000 miles with no apparent problems so far. However, the I30 does have a "whirring" sound I have not been able to locate (but ruled out alternator, tensioner, AC pulley). I'll have to inspect the crank pulley closely.
Old Sep 23, 2010 | 07:32 AM
smoketheresfire's Avatar
My pulley lasted 225k miles.
Old Jun 2, 2013 | 05:46 PM
Rltkktlr's Avatar
Crank pulley
Mine is gone. Didn't hear much but changed a bad serpentine belt and when I shredded the new one I started looking for the cause! Not my proudest moment. But anyway have to figure out how to get old pulley off. Has to be on there tight. Probably try impact tools. Anyway 95 maxi with 148k.
Old Jun 2, 2013 | 06:25 PM
Trini Boom's Avatar
Well it appears the age of the rubber is the cause here and not the mileage after several reports..
Old Jun 3, 2013 | 06:46 AM
Max_Gator's Avatar
Knock on wood, I have not had a problem yet with either of mine. (Now, I know I will have one next week).
220k on the 2000 and 290k on the 1996.
Old Jun 3, 2013 | 10:16 AM
catalinvint's Avatar
Mine went out a month ago, at 226k km's.
It was making weird noises for the last couple of days like metal grinding on metal at high speed. Imagine when a train stops into a station, smth like that .
One morning I started the car a a big bang and a pulley was spinning in front of my car.
So yea, when you hear the noise change it
Old Jun 8, 2013 | 10:06 AM
iDuty's Avatar
Mine lost it a year ago, at about 132K miles. I suspect that this is more age related than mileage, as mine was almost 16 years old at the time. As others wrote, you do get some warning.
Transmission in gear and hold the brakes only works with manual transmissions.
Breaker bar held steady to the floor while wife bumps the starter works well to take the bolt off, that is what I did. But I had no way to tighten it back on, I had to borrow an impact wrench to do that.
mvm062
Nov 30, 2020 09:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
gustavison
Oct 4, 2015 06:50 PM
The Wizard
24
Oct 1, 2015 08:47 PM
conansriver
Sep 11, 2015 10:26 AM
