car doesnt start sometimes
Old Sep 3, 2010 | 07:01 PM
kasemodz's Avatar
Well, this has been a problem for a while now. If the car has been resting for a while, and if I try to start the car, nothing happens, no cranking nothing. If I leave the key in the on position for about 5 seconds, and then I try to start, it starts up just fine without any hesitation. After researching a little, I think it's either the fuel pump problem or fuel injectors. I'm just not sure which one is a more likely cause. I did install a new fuel filter recently, but that didn't help. Please advise, thanks.
Old Sep 3, 2010 | 07:32 PM
SchofieldRacing's Avatar
I don't think fuel is your problem... If your fuel pump was out, the car would still turn over. I would look into the ignition itself. Good Luck!
Old Sep 3, 2010 | 07:52 PM
Trini Boom's Avatar
This is either an ignition switch problem or a grounding problem... Also, have you tried starting the car in Neutral??
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
