could this guy (harness) couse p1400? see pic
Old Sep 12, 2010 | 06:37 PM
mateusz1945's Avatar
last time when i replaced knock sensor i noticed that i am able to pull this cable from socket (green). Looks like someone in past tried to solder it but it didn't help, so I've put it back in place, recently i am getting CEL P1400 (EGR valve) and sometimes p0400, could it be because of this harness? if not ,what is that for anyway? ow and it is 98 SE
close up:
Old Sep 12, 2010 | 09:59 PM
Trini Boom's Avatar
If the code was never there and it came up after you touched it, then yes, it could be the harness itself. You will need to go to the JunkYard and cut off one and splice it in. That is the EGRC Solenoid Valve and with that code, you will not be able to pass emissions.
Old Sep 13, 2010 | 12:05 AM
ColombianMax's Avatar
Yes thats the EGRC and it will cause a P1400, you can ohm it out to see if its good or bad. Let me search for a post I made last year and I'll get back to you with the info
A lot of scanners will say its a Manufacturer code or some bs like that and it wont tell you what it is
Old Sep 13, 2010 | 12:18 AM
Here ya go, this one even has a few pics. Good luck
http://forums.maxima.org/7215367-post61.html
http://forums.maxima.org/6429395-post5.html
Old Sep 13, 2010 | 12:49 PM
JtzMax's Avatar
Whatchyou say?
Why does it look like that car has been under water at one time? Maybe it's just me, but you don't normally see rust on things like the intake clamp / TB.
Old Sep 13, 2010 | 01:42 PM
luke95gxe's Avatar
my thoughts too
Old Sep 13, 2010 | 03:29 PM
fkmax's Avatar
Originally Posted by luke95gxe
my thoughts too
Don't rub it in guys It doesn't take long for a car to distintegrate with all the salt they throw on the roads in winter here. I imagine Connecticut is just as bad.
Old Sep 13, 2010 | 03:46 PM
Sweet. i checked and it was around 38 ohm when warm, so only problem is this socket, going to visit junk yard soon. Problem solved thanks!
this frickin' car was under water , but i needed car...and it was Maxima and it was fully loaded , and low millage, and looked good, and seller said the smell is only because car wasn't used over a year!! and i was so tired of buying/searching and so cheap not to check carfax.
But, it is driving good , i replaced lately alternator. I'd Better clean my groundings until another die. what else should i do/check with this "kind of car"?
Old Sep 13, 2010 | 03:57 PM
actually i am not sure about this "under water" history, but body is not rusted , so i am guessing car could be maybe from Florida with little hurricane bath or something?
Old Sep 13, 2010 | 04:13 PM
atriuum's Avatar
tri-state area humidity..., curious what your radiator support looks like...
Old Sep 13, 2010 | 06:17 PM
Trini Boom's Avatar
Umm, I have rust on my clamp and my car has never been under water. I do degrease and wash my engine bay which could also cause rust...not only flooding.
Old Sep 13, 2010 | 10:19 PM
I got the this update on my cell phone and I thought you were talking about MY car, which DOES have a bit of rust in certain parts under the hood and to my defense I got the entire snorkel and air box/duct from JY cuz I broke mine when doing my clutch. The Maxima I pulled it from had no hood and was at the JY for a while so that would explain my reason for having a slightly rusted part, other than that I have a perfectly legitimate reason, I'm in Chicago and I didnt buy my car new
However, that doesnt matter because you were referring to the OP
OP, glad I was able to help. Now if someone would be nice enough to help me and infowire with infowires problem. We are fresh out of ideas! Sorry to "hi jack" but its really annoying me not being able to figure the problem out!
http://forums.maxima.org/4th-generat...d-lagging.html
Old Sep 13, 2010 | 10:22 PM
oh and another thing I forgot to say... you're all worried about it having the rust on the clamp while I'm concerned/unpleased that there is a red ball type cap in the engine bay... eww
nismomaxgtr18
Forced Induction
20
Mar 5, 2016 08:04 PM
JMag90
Aug 25, 2015 09:17 AM
maxipower
Aug 21, 2015 11:10 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
