Strange brake noise
Old Sep 19, 2010 | 08:14 AM
smackdown85's Avatar
Strange brake noise
Ok here is the situation...
While cruising along (without any brake applied) my front left brake will make a loud squeeking sound. It is intermittent though, so it will squeek for 15 seconds or so, then just randomly go away, usually if I hit a bump in the road or something. If it doesn't go away after a little bit, I'll hammer the brakes and it sometimes will stop. Then it will just start back up again eventually.
Thanks in advance, and let me know if you have any questions.
Old Sep 19, 2010 | 10:05 AM
najee1062's Avatar
I would say check out your pads, rotor, caliper and brake hardware kit to start.... you may just need to service them... like lubing up the pins and sliders, replacing the hardware kit and pads...
Old Sep 19, 2010 | 11:03 AM
max_dreamer's Avatar
how long since your last brake job?
maybe your starting to hit the brake wear indicator...
maybe those clips in the caliper that pull the pads back away from the rotor arent doin their job!
pull it off, lube it up, check everything, throw it back together... 20 minutes, maybe...
Old Sep 19, 2010 | 11:42 AM
Maximum_Chaos_95's Avatar
i have the same problem but my brakes are fine i checked them a couple weeks ago ....
Old Sep 19, 2010 | 11:44 AM
96i30azn's Avatar
you checked all the pads? the inner pads which you can't see sometimes wear faster than outsides. you have to take the wheels off to see them through the caliper windows
Old Sep 19, 2010 | 12:00 PM
luke95gxe's Avatar
had the same problem interminted squeeking it was that pads changed em problem gone
Old Sep 19, 2010 | 05:05 PM
NeptuneMan's Avatar
Hey, if you check them regularly - that may be your problem, especially if you use cheaper brake pads. The oil from your fingers when you're checking all that can be the cause, when reassembling be sure to soak everything really good with your handy can of brake cleaner.
Old Sep 19, 2010 | 06:05 PM
Remember, I'm having the problem while NOT applying the brake. While driving it makes the squeeking noise, when I brake it typically stops it temporarily. You guys still think it's the pads?
Thanks for all the input everyone.
Old Sep 19, 2010 | 07:36 PM
najee1062's Avatar
Yes it still could be your pads.... It sound like you're just getting low on pad wear if your squeeking is while not applying brakes. Once you hear that all the time you are really low and could cause damage to the rotor... Also you could be using cheap pad that tent to squeek when there new or braking in. I use Hawks... they are the best deal.
Old Sep 20, 2010 | 07:59 PM
i did notice uneven wear ..... would wetting the pads after the heat up affect them ? for example i drove around for like 2 hrs then washed my car
Old Sep 21, 2010 | 08:48 AM
Goomz's Avatar
that squeak is telling you that your pads are wearing down and need to be replaced and while your at it, resurface/replace your rotors!
Old Sep 21, 2010 | 01:26 PM
FIXED
Yes, it was the pads being low. Actually only the outer pad on the left wheel was super low. Good thing I had bought the lifetime warranty pads from Autozone, so I just swapped them out for no charge!
I appreciate all the info from everyone!!
Old Sep 23, 2010 | 05:45 PM
newjerz's Avatar
Check the rotors you might have a small rock caught up in there. That happened to me back in 1999.
Old Sep 23, 2010 | 05:47 PM
newjerz's Avatar
sorry about that. posted without reading all the way through the thread.
tarun900
19
Dec 20, 2021 06:57 PM
D Mason
Jun 21, 2016 04:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
