Getting off the Clearance Lights
This may sound like a stupid question to most of you guys, but for the life of me, I haven't been able to get off my clearance lights on my 97 GLE. Can anyone give me directions how to? I unscrewed the top and was able to pop the side out, where the flap holds it in, but there is something on the bottom holding it in I think. How do I get them out? Thanks.
Re: Getting off the Clearance Lights
Re: Re: Getting off the Clearance Lights
"The clearance light is held in with a 'ball and socket' joint. To pop out the light, use a Flat Head Screwdriver wrapped in a towel to pry it out. Using a towel will prevent damage to the clearance light."
Will that not do damage to the joint? or is it meant to be popped out? And will I have to exert a lotta force into it?
Thanks again
Re: Re: Re: Getting off the Clearance Lights
i think the first time you need to use some 'extra force.' The clearence light has a metal shaped 'peg' that is pushing into a socket. I can't describe it that well. Just make sure that you pry at the bottom of the clearence light, not up where you took the screw out. Hope this helps.
well, still no luck...i went down and pryed as hard as i could, it even took a little chip off the plastic, stupid thing would not come out, so i just snapped it back in...i'm tryin to get it out to change the bulb to the hyper white kind, so it'll match the xenon bulbs i put into my headlights
thanks for the help tho guys, any other suggestions?
Originally posted by 97BlackMax
would it help to try and spray some WD40 onto the socket?
NickStam, none of the links at the top of the linked page work and I can't seem to find any links to your 'how tos' on your homepage.
I put in hyper white lights in the side of my corner lights and its stillhas the dirty white color
Thanks guys, I might try the WD40 sometime. But right now, my dad isn't too happy because he is really afraid that I'm going to break it, and then I would definately be in some big trouble. But in regard to the dirty white color, what exactly do you mean? Even if it is dirty white though, I'm sure it would still look better on my car next to the xenon headlights than does the yellowish vs. white contrast.
Thanks again.
Thanks again.
Get a flashlight and pull on the light with your fingers. Shine the light down, pretty much inline with the clip that holds the housing with screw. You should notice the post and socket. Now use a large screw driver and put it between post base and socket. Now twist the screw driver. It'll pop!
Originally posted by Anachronism
Definitly, I was going to suggest that before I saw your last post. When I pulled mine out I thought I was going to break something for sure, because it was so hard. I didn't see NickStams write up before I did mine (excellent write up BTW), but the one I looked at (Maximadriver.com?) recomended WD-40 in the socket. After you pull it out the first time it should pop in and out fairly easily.
here's the rest of them
http://216.119.94.9/howtos.asp
lowpost99
Oct 26, 2025 06:53 PM
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
