Knock sensor bypass, what am I doing wrong?
Old Oct 1, 2010 | 03:34 PM
xj0hnx's Avatar
So I've read pretty much all the KS thread, and decided to do the bypass until I get my new knock sensor. I disconnected the subharness, and placed the 470Ω resistor in the connector, cleared the code, drove, no CEL, then pulled the code and 0304 popped up, I tried to add a 100Ω in series, so one pin ->100Ω->470Ω-> other pin, that still threw the 0304. I then tried them in parallel with both the 100Ω and 470Ωends both going into each pin, it still thew the 0304. I tested the harness and got 566Ω so it's got to be something I am doing wrong with the resistors.
In parallel ...
The resistors I am using ...
Old Oct 1, 2010 | 07:11 PM
asand1's Avatar
Wrong resistors, you want 470,000 or 470K. Radio shack #271-1133.
Color code gold, yellow, violet, yellow.
Old Oct 1, 2010 | 08:48 PM
xj0hnx's Avatar
Awesome, thanks, that's what I get for not writing it down before going to the store .
Do I need to clear the code after I put in the resistor, or will the ecu clear it on it's own once it sees what it needs to?
Old Oct 1, 2010 | 10:51 PM
asand1's Avatar
Clear it.
Old Oct 2, 2010 | 08:39 AM
xj0hnx's Avatar
Ok, cleared the code, installed resistor, drove home, pulled 0304 again, then reseated the resistor, started and ran the motor for a couple minutes, turned it off, and pulled 5 by 5 from the ecu so hopefully it will hold next time I drive.
ballerchris510
Sep 23, 2015 08:46 PM
homeofbacon
Sep 23, 2015 07:17 PM
ac max 92
Sep 17, 2015 07:35 AM
