Parts recommended for a Suspension Rebuild
Old Oct 5, 2010 | 10:39 AM
dgoodhue's Avatar
I have 127K on my I30 and some parts of my suspension needs replacement. I drive a lot highways miles and plan on driving this car another 50k maybe 75K miles (2-3 years). My dust boots are ripped, strut bearings making noise and on of my front struts is creaky is what I have diagnosed so far. Their maybe other things but that is what I know definitely is wrong. I would love to do Illumina’s & H&R Springs but the replacement cost gets expensive fast.
I am planning on just doing Tokico Blue Struts with OEM springs I was almost thinking about just doing the fronts as my rear suspension doesn’t make any noise, but from what I have found it more cost effective to buy a set of Tokico’s, so I am going to do front and rears.
Beside the dust boots and strut bearings what exactly is must do. I have read the FAQ and done many searches, many of them pretty much say replace everything. I would like ot save some money if I can, but I also don’t want to be pulling the suspension apart next year either. Do I really need to replace the rubber spring mounts or can I reuse my originals? Do I really need to use OEM strut mounts or will the Moog ones do (in general Moog makes quality suspension parts)? What about Ball Joints, Sway bar links, Control Arm bushings, etc.
Old Oct 5, 2010 | 01:43 PM
neosmatrix's Avatar
Dave, if I were you I would just use the Monroe Quick struts as its much easier and usually cheaper.
The Moog products are good and safe to use.
As far at the rest, not sure.
S
Old Oct 5, 2010 | 02:21 PM
99sagelimited's Avatar
I just did mine recently, and here is what I used:
FRONT:
KYB GR2 Struts & Dust Boots(Comes with bump stops)
OEM Front Strut Mounts
OEM Strut Bearing
I re-used everything else up front with no problems.
REAR:
OEM Spring Insulator (P/N 55034)
OEM Bushings (P/N 56217 & 56218)
OEM Strut Pin and Nut (P/N 56226)
I had no problems with this, and the car rides like new again. I forget what I spent altogether but it was around 400.00. I would say you definitely must replace the front bearing and mounts at a minimum. For the back, I noticed the OEM stuff isn't too pricey, so I went to replace just about all of it. I used courtesynissan for everything but the KYB's. Those were ebay for 200.00 brand new!
Good luck.
Old Oct 5, 2010 | 04:44 PM
beegeezy's Avatar
S
I thought the monroe and gabriel quick struts aren't recommended for our cars because they don't fit properly?
99sagelimited, that is essentially what I'm going to do on my car this winter break. I'm going to be turning 150k on the stock suspension pretty soon. I'm probably going to use the Tok. blues but I may consider the gr-2s if the saving are great enough.
Old Oct 5, 2010 | 09:13 PM
maxed_out_99's Avatar
im under the assumption that you do not want a lower stiffer ride
Old Oct 6, 2010 | 03:33 AM
dgoodhue's Avatar
I am little gun shy about lowering the car. My last car (not a Maxima) had KYB GR-2 struts and Tein H-Tech Spring. It was a little stiff for my taste, but my wife absolutely hate it and constantly complained. I don't want a repeat and she maybe overly aware of any suspension changes because of my last car. I did like the way my last car handled and I think could probably get away with some progressive H&R springs. I wouldn't mind something slightly stiffer (my research tell me tokico and H&R springs seem like they would be the right combo).
Cost is also coming into the picture. I atleast into the suspension for $600, springs would bring it closer to $800 ($1000 if I want Illuminas) and I haven't checked the sway bar hardware or LCA.
Old Oct 6, 2010 | 03:46 AM
95Maxed's Avatar
Cattman has a deal out there man, 550 for all four KYB AGX struts AND Progress Springs. Thats the route ime going when I get lowered.
Old Oct 6, 2010 | 06:34 AM
NetFurie's Avatar
You can get illuminas (springs and struts) for 600 shipped from ebay. That's where I got mine several years ago.
As far as the other components... I would recommend replacing the bearing instead of trying to regrease it. Autozone has the mount (insulator) with the bearing for $35 each side. I originally tried regreasing mine during the install but ended up having to replace it a couple years later.
That and new dust boots and you should be fine.
Old Oct 7, 2010 | 12:24 AM
ef9's Avatar
ef9
Anyone have the KYB AGX and Progress Springs? If so, how do they ride?
Old Oct 7, 2010 | 08:12 AM
pemd5555's Avatar
what about the tein s tech springs?
Old Oct 7, 2010 | 05:50 PM
808s96SE's Avatar
I installed the Tokico HP kit on mine. Replaced the front and rear strut mounts, bearings, etc. Both my gf and I love the way it rides now.
Old Oct 7, 2010 | 06:14 PM
eFLO's Avatar
got any pics? i'm trying to see how much lower it is with the tokico springs. i believe it's only around 1.3-1.4 drop. i'm on the fence between the tokico hp and gr2 & maxspeed springs.
Old Oct 7, 2010 | 09:07 PM
dude, honestly, if the rest of the suspension is in good repair i wouldnt mess with it replace whats bad and be done. it sounds to me like you dont want a stiff ride so go oem.
Old Nov 2, 2010 | 06:15 AM
talisman311's Avatar
I swapped all my shocks/struts to KYB GR2s around 160k miles and it was a massive improvement. GR2s are slightly stiffer, but I wouldn't say very stiff comparing to my sport suspension BMW. It's more like a non-sport BMW 3 series if I had to compare.
Other things I'd change is:
- Tie-rod dust boots (will need to get an alignment after)
- Replace lower control arm bushings/ball-joint, one of the forum sponsors has a complete set for ~130 and I believe includes bushings for the sway bar to control arm joint. Trust me, replacing the whole arm is much easier than replacing the ball-joint. Additionally the chassis to LCA arm might be seized on the driver's side within that bushing so I'd buy another one just in case. Your passenger side bushings for the lower control arm might be worn out. Either oil or power steering seems to get on this bushing and it deteriorates over time.
Old Nov 2, 2010 | 06:44 AM
BlackMamba's Avatar
ef9: i have KYB AGX and progress, and with the settings dial in at 1front 1rear
its mild, meaning, it can almost go unoticed, for me. At 4front, 8rear , the
car becomes a go-kart.
Old Nov 2, 2010 | 10:35 AM
RA021526's Avatar
I just replaced my entire suspension, front and back, not that long ago. I spent a bit more than I had intended, but I got what I paid for, for sure. I spent $1500 (or so) and put in Tokico Illuminas and H&Rs. I replaced just about everything. New bearings (a must) mounts, bushings, etc. Mind you, all of the stuff on the car was pretty worn out, there was no way I was going to put any of that back on the car. I wouldn't get the KYB boots for the Miata/Mustang, they didn't fit quite right. The Maxima boots are probably just fine.
If you're going to be doing the suspension, definitely check out other things too, control arms, tie rods, sway bar links, etc. There's a kit in the group deals sub forum that has all of that.
Bottom line: if I did it all again, I'd buy all of the same stuff.
Although, the guy at the local Nissan dealership said I should just buy Quickstruts. So, I just went through courtesyparts.com
Good luck.
Old Nov 2, 2010 | 01:57 PM
ef9's Avatar
ef9
Progress springs have a really comfortable spring rate. Cattman has a good price on that combo. I think it was $550 or something like that.
Thanks for the insight, now I know exactly what spring/shock combo to purchase.
Old Nov 2, 2010 | 07:02 PM
jholley's Avatar
+1
The lowering springs in the HPK245 kit will drop you 1.4" in the front and 1.25" in the rear. The HPK245 kit includes the tokico blue struts. I replaced my OEM springs and struts with that kit eariler this year.
Old Nov 10, 2010 | 06:59 PM
5150pa's Avatar
Originally Posted by jholley
+1
Any Before/after pics?
Or maybe just after
Old Nov 10, 2010 | 09:04 PM
max ride 41's Avatar
i have gr2's and no issues. 2 years ago last month and 32,000 miles without a problem. maxspeed springs and new oem bearings and strut plates and oem boots which i cut to avoid too much travel. you can re-use the spring isolators if not too chewed up, i did. remember that the suspensions got to settle in for a week or 2 before you acheive proper ride height. also, get it aligned afterwards, your toe and camber will be off a bit.
Old Nov 11, 2010 | 10:54 AM
maxispeed's Avatar
im prolly going to have to redo my suspension this coming summer and was wondering the same thing as the OP. only difference is, do you guys suggestadjustable coilovers or just buy ones that lower it and call it a day. the reason i want adjustable is because i live in chicago and want to raise it in the winter because of the snow.
Old Nov 11, 2010 | 01:49 PM
well, i have the standard gr2's as stated in my previous post, and sometimes coilovers can be really stiff compared to a regular strut. i've been told that any lower than 1.5 front and 1.3 in the rear is putting alot of stress on the suspension components.
Old Nov 12, 2010 | 07:09 AM
dgoodhue's Avatar
Just lower it and call it a day. Maxima's sit pretty high, in most instances an extra 1.5" isn't going to make a difference in snow. After lowering it, my last daily driver had much less ground clearance than the average lowered Maxima and I never had any issues ground clearance issues. I put some good snow tires on it and It was great. Sometime I heard some snow hitting the under side, when I hit some of the deeper stuff, but it didn't affect the way I drove the car.
Old Nov 12, 2010 | 10:01 PM
maxispeed's Avatar
^^^ do u have the snow tires on the stock rims or do u leave aftermarket rims on once the snow hits?
Old Nov 13, 2010 | 05:59 AM
dgoodhue's Avatar
I have only had my I30 since this summer, but it will be getting snow tires mount on the stock wheels. I will get another set of wheel this summer for the summer tires.
Old Nov 13, 2010 | 09:15 AM
Br0nz's Avatar
i have used the quick struts in multiple cars and i love em. they include EVERYTHING and pop out whole no fussing.
http://www.amazon.com/Monroe-171683-Quick-Strut-Complete-Assembly/dp/B000V526FQ/ref=au_pf_pfg_s?ie=UTF8&Model=Maxima|891&n=1568418 1&s=automotive&Make=Nissan|67&Year=1998|1998&carId =014
$600 total and lifetime warranty.
wait scratch that rock auto has em for 120$ find a 5% off coupon and your good to go!
$563 shipped for all four
Old Nov 13, 2010 | 05:14 PM
monroe is like stock and imo they suck. i went through a set of monroes in the rear in a little over a year. both were flat as pancakes....mmmm, pancakes...
Old Nov 13, 2010 | 06:17 PM
Br0nz's Avatar
i like the stock ride i think they really do a good job of returning the car to org stock feel as everything is replaced not just the cartridge.
Old Nov 14, 2010 | 08:10 AM
dgoodhue's Avatar
The hardest part about struts is pulling them out. It's not usually that bad either, but some cars are harder than other depending what is attached to the sturts. As long as you can get the top nut off the assembly, its just a spring compressor and simple Dissamble/Assemble.
Old Nov 16, 2010 | 07:13 AM
pitfall87's Avatar
+1
What's included in the HPK245 kit? My real question is will I also need to buy the mounts and boot kit or is everything I need included in the HPK245?
Old Nov 16, 2010 | 08:13 AM
jholley's Avatar
All the kit includes is 4 tokico blue struts and 4 lowering springs. A little google searching could answer that for you.
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
deezo
Aug 16, 2015 06:21 PM
Team STILLEN
Aug 10, 2015 04:29 PM
