pvc intake piping...
i'm thinking of making a custom cai but out of pvc piping. yes it sounds ridiculous but think about it, intakes are made of aluminum. aluminum is stil some type of metal, and will heat up under the hood (not as much as most metals but still heats up). pvc doesnt heat up much (or at all) when heat is applied. so a cai intake made out of pvc will hold and let air travel through into the throttle body with the air being the same temp as the air outside of the engine bay (which is the purpose of the cai). i was given a pvc cai years ago when i first got into imports, and to be honest it performed a bit better than a AEM cai (which was probably the only aftermarket intake make in 2000 2001 aside from iceman).
so i guess what my point for this thread is, your opinion on this. yes it make look a bit odd when the hood is open but my thing is performance over looks...
Actually I think if you paint your PVC piping black no one can tell that its PVC. Esspecially if you use automotive paint where it has that little sparkle in it and then put some clear cloat over that.
^^^the one i had on years back i sold it and the guy that i sold it to painted it. look legit but the pvc elbows gave it away. i'm thinking of eliminating the elbows and just cut the angles needed to make it look less plumbingish lol...
thats a good idea...
I just got my PR style CAI pipe that attaches to the MAF and goes into the fender, even that'll be header wrapped. That plus my custom heat shield (thanks Russ ), should keep intake temps way down.
I'll probably also be removing my driver foglight to get more cold air if the filter sits way behind that oppening but I'm not sure if it does..
You mean performed lol but I get the idea. That sounds good to me. I hope my cone filter sits somewhere down there, I've never had a true CAI before.
wrapping also keeps the heat in once its already heated, so it really isnt the greatest thing to do either.
i believe when PVC is heated (it will get warm under your hood) it leaches vinyl chloride into your engine. not sure if that's the best thing for your motor.
just in case you start inhaling the fumes that comes from your super cheap intake PVC tube...
Vinyl chloride has been shown to cause liver, brain, and lung cancer, as well as lymphatic and hematopoietic malignancies (such as lymphoma and leukemia) in multiple epidemiologic studies.
if you want good heat rejection ceramic coat your pipes.
thats no fun...if you want a cai get the aluminum pipe...you can usally find them from time to time for $20 on here and i wrapped my midpipe and cai pipe
works great for me
Yowza... Learn something new everyday.
What kind of plastic is the stock intake made of?
Yup, got my CAI pipe for $25 shipped. I already have my mid-pipe wrapped, CAI pipe will be too once its installed.
All the research I've read has said that intake air simply travels too fast to be strongly affected by engine heat. By making your intake out of an insulator or wrapping it, you're probably lowering your intake temp by less than a degree, at least at WOT when air is moving the fastest.
On the same grounds, I doubt that PVC or ABS or whatever type of plastic you decide to use will actually get hot enough to release toxins at a significant rate, unless you idle a lot in the desert. Just to be safe, though, I would consider making an intake out of ABS piping instead of PVC to avoid those hazards.
Yeah I think although the outside of the intake might heat up but the inside will be cool from the air moving inside of it.
And I don't know how hot is actually gets but my intake piping is only warm to the touch after like an hours drive. Unlike the radiator and other things that are considerably more hot. And so just like another member said I don't think your intake piping can get hot enough to release toxins... unless... you drive in the desert.
And who knows those toxins might act as nitrous oxide and give is a slight boost
One thing I wonder is... what if you add A/C lines and coil it around the intake to super chill the pipes. Would that cool down the air fast enough to make it act like a cold air intake to increase power while having that advantage of a short pipe during high RPM? Hmmmmmmm.....
like i've said, i've already had an intake made with pvc and didnt have a problem with it. but the only difference was that it was in a civic and the engine bay temps are different compared to a 4th gen engine bay...
^^ hey i have the same battery. i hate to say it but the intake piping at pep boys works great and is made of pvc or some type of plastic it comes in all angles and looks nice too. one other thing i noticed is it DOES NOT retain heat it was 20 degrees cooler than the engine.
One way to actually find out, get something that plugs int your OBDII and view the intake temperature. That way we all have some real valid proof that it works or if it's just rumors/myths.
you should try using the PVC and seeing where it leads bro. If you used a similar setup on your 00-01 civic, it should be fine. Our exhaust manifolds aren't really close to where the piping is going to be anyways. In civics, they usually go down and sit right by the headers. Oh yea i forgot to mention that the melting point of PVC ranges from 100-260 degrees Celsius. if your really worried, you should heat wrap it and it wouldnt get extremely hot, plus that would hide it so nobody would even know its PVC lol.!!
i'm not telling you to drink the oil or sniff the fumes from a hot PVC pipe. i'm saying that the chemicals that leches from the PVC pipe is not good for the engine.
during idle the velocity of the air going into your engine is quite slow/low.
i'm not going to sit here and argue with you guys that can't afford a metal pipe and two couplers. it's your motor and your car...i'm just throwing some warnings out there so you don't come back saying that there's a mysterious coating inside your intake manifold and it's causing weird issues with your car.
do you have links to these so called "research"?
In the interest of science, I actually found something that might contradict my earlier statement. In the link below, the experimenter managed a significant drop in intake temps by insulating his intake. The experiment was in no way rigorous, though.
http://forum.ih8mud.com/80-series-te...xperiment.html
In plumbing, you are not supposed to use pvc pipe for hot water because it softens as it gets warm. IIRC, you heat pvc pipe to 180 degrees if you want to bend it. This may not be a problem while the car is being driven, but after you park the car, especially in summer, this could be a problem.
I had a pvc y intake pipe. Basically it was part true CAI and part SRI. First filter sat behind the battery while the second was routed like the injen but the filter sat ziptied to the lower front grille. I also bought blockoff plates for them so I could choose between either, or, or both. I painted it a flat silver so it actually didnt look too bad. Couldn't complain about the performance either except for the loss of low end tq which is pretty much the norm for this mod. Its really more of a "sound" mod anyways. But at WOT with both open, the VQ roars .
Will upload pics of the setup as soon as I get a chance.
Pretty bad. A woman backed into my driver rear quarter panel so rims shoppin' is gonna have to hold off till that's fixed.
Thats a crazy *** set-up, I've never seen anything like that. What size piping is that? Looks huge no homo.
