New Spark Plugs = Harder Start
Old Oct 13, 2010 | 07:04 AM
Swazey's Avatar
I replaced my spark plugs last nite because i have been getting horrid gas mileage and my 96 maxima has lost some of its get up and go. The replacements were the same as the ones in there, NGK platinums. when i took the spark plugs out the tips were white.
I have been dealing with a hard start issue ever since i replaced my clutch years ago. the car will start but just not right away. takes 2 or 3 tries. sometimes it does start right up but usually takes a few cranks.
now that i have installed the new plugs, the car takes 5 to 6 turns to start. the car wants to turn over, kind of burps and after a few cranks it turns over. it runs perfectly fine, idles fine and the low end power is back.
i added 3 ground wires, cleaned all my grounds, got a new air filter (k and n with frankencar intake) the starter is strong but i do have a recharged battery i got for 35 bucks. it reads 14 volts on my voltmeter. could my battery be going?
any reason why new plugs would cause me to have a harder start?
Old Oct 13, 2010 | 08:26 AM
JDM4LIF's Avatar
did you check the gaps on the plugs? the smallest mm makes the diff.
Old Oct 13, 2010 | 09:39 AM
bullet187's Avatar
You could try cleaning your Throttle Body, some times it causes hard starts. I havent heard of spark plugs causing hard starts especially if you tried new spark plugs and it didn't help. The other possibility is your starter is on its way out and the new spark plugs require more power to start.
Old Oct 13, 2010 | 10:14 AM
Swazey's Avatar
i did not check the gap on the plugs before i installed them. arent the NGK platinums pre-gapped and do not need to be checked?? (writing that makes me feel like an idiot)
I cleaned the throttle body, iacv and all that a few months ago. there was hardly any carbon build up at all. i hope its not the starter but it could be. its the original starter pushing 150k and ive had a starting problem for years. its a beast!
new starter and new battery may do the trick, i just dont have that kind of money to spend right now, urghh
Old Oct 13, 2010 | 10:38 AM
Justaguy's Avatar
maybe put the old spark plugs back and see what happens.
Old Oct 13, 2010 | 11:07 AM
Swazey's Avatar
just went out for a lunch break and car started right up on the first crank. it is 15 degrees warmer than it was this morning. very strange
Old Oct 13, 2010 | 01:06 PM
asand1's Avatar
1 NGKs are pre gapped.
2 NEVER gap platinums, you destroy the platimun.
2 milleage and sluggishness sounds like KS, run codes whether u have CEL or not.
3 If its cranking slow its starter, cables, or battery.
Old Oct 14, 2010 | 12:16 AM
FallenOne's Avatar
Hi im FallenOne and I approve this message!
Old Oct 14, 2010 | 05:08 AM
S1cTech's Avatar
u said you been having issues since the clutch was last installed? did you put on any different type of flywheel or something with a different ring gear? are there any codes? You might of forgottin a switch.
Old Oct 14, 2010 | 05:37 AM
Br0nz's Avatar
lol
... i know you said you added grounds but check the one to the starter and tranny also i had a hard start after forgetting to reconnect the airbox air temp sensor or whatever its called does the frankencar delete it?
Old Oct 14, 2010 | 09:14 AM
asand1's Avatar
You may have bad grond to your starter. Test with a jumper cable from your batt neg to starter mount bolt.
You may have to clean mating surfaces on starter and trans.
mvm062
Nov 30, 2020 09:00 AM
9aj9
Apr 5, 2020 12:11 AM
trungg86
Sep 4, 2015 04:58 AM
