Car doesn't start, acts like it has no power even when jumped
Old Oct 24, 2010 | 03:20 PM
88FordFestiva's Avatar
I left my car in a parking lot for 5 days, and when I came back it had no power at all. I got it jumped and it worked just fine. After sitting overnight in front of my apartment, the next day it was dead again. Only this time, jumping it didn't work. I even tried switching the battery with my friend's.
Basically, it just didn't seem to get enough power. It sounded and felt just like a dead battery, only that didn't make sense in the situation. Do you guys have any idea what it could be?
Both the battery and alternator have been replaced within the past year. All of the fuses next to the battery are fine.
Old Oct 24, 2010 | 03:24 PM
JNCoRacer's Avatar
Just the tip.
Have you checked the big 120 amp fuse in the fuse box next to the battery?
Old Oct 24, 2010 | 03:39 PM
Yes, all of those fuses are fine.
Old Oct 24, 2010 | 04:59 PM
shiloh51933's Avatar
Possibly the starter solenoid or fuel pump, it depends on symptoms. I would look into your starter first cause from what you posted it sounds like the solenoid is shot or the starter motor.
Old Oct 24, 2010 | 06:19 PM
Trini Boom's Avatar
on the starter. I would remove and have it tested.
Old Oct 24, 2010 | 08:40 PM
metaverse's Avatar
Just had a similar problem with mine last winter. Problem = starter.
Old Oct 25, 2010 | 02:03 PM
DennisMik's Avatar
That was my car last year. Cranked slow if it cranked at all. I had the starter "tested" at autozone and was told there was nothing wrong with it. Finally swapped starters with my other car and then car 1 started and car 2 wouldn't. Turns out the lube for the planteary gearset inside the starter had dried up and was binding the gears. But autozone said there was nothing wrong with the starter. Went to O'Reilly's and got another starter.
Old Oct 25, 2010 | 02:15 PM
bnrz's Avatar
Turn the key, if you hear a click the solenoid is fine and the starter motor is bad.
If you hear no click there's no juice getting to the solenoid.
Old Oct 25, 2010 | 02:16 PM
greymaxima's Avatar
Tap the starter to see if might start or check the battery.
Old Oct 25, 2010 | 04:28 PM
schmellyfart's Avatar
Take it apart and see if the brushes are worn down. Replacement brushes are only $30 (compared to >$100 for a new starter) on rock auto. I replaced the brushed two weeks ago and it has started everytime since the replacement.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
JRod28
Feb 4, 2016 11:07 AM
maxinout93
Oct 27, 2015 01:29 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
