climate control swap
Old Oct 28, 2010 | 01:02 AM
lux97Max's Avatar
i have the standard 97 auto climate control module, and i was to swap it out for a 99 one, reason is because i think it looks better, it has all the buttons and features like the one i have except it has the amb button which i don't no what it does, other then that they are identical except the buttons are re-arranged different. any how is this possible to do, or is it alot more work to handle.
Old Oct 28, 2010 | 02:55 AM
Br0nz's Avatar
im not 100% but i believe they swap. the amb button tells you ambient temp outside the car. you could mod some of the older CC to add amb too lol
Old Oct 28, 2010 | 10:43 AM
fat_kid's Avatar
Search, im not sure it's a direct swap.
Old Oct 28, 2010 | 11:04 AM
lux97Max's Avatar
i tired and its not a direct swap i think ima have to do trial and error but and ideas>?
Old Oct 28, 2010 | 03:15 PM
supachin's Avatar
it's not a direct swap. the plugs don't match up and there's a whole leap of sensors you'll need to get. it's gonna be money!
i thought i could do that with my 94 altima, epic fail. and i looked it up for our ae's and another fail!
Old Oct 28, 2010 | 04:07 PM
lux97Max's Avatar
you sure i mean i have the auto not manual everything seems to be the same just connect colors with colors
Old Oct 28, 2010 | 04:31 PM
JAMAICANLOVRBOY's Avatar
the amb button must mean the 99s have an outside temp sensor, i guess you would have to get the climate control harness and sensor to use the feature
Old Oct 28, 2010 | 05:07 PM
lux97Max's Avatar
i got everything the harness and module jus need to re wire color to color i guess
Old Oct 28, 2010 | 05:16 PM
oh ok gotcha.
Old Oct 28, 2010 | 05:22 PM
lux97Max's Avatar
ill take pics and do a write up on it when im done i no the people i get my custom work done will be able to figure it out,
Old Oct 28, 2010 | 06:23 PM
DennisMik's Avatar
The pieces you need to add that I can quickly thing of are: You need to change out the resistor for the blower motor with the transistorized one. You have to add a sunlight sensor on the top of the dash by the defroster vent, you need to add the inside air temperature sensor and hook it up to a vacuum source and add the outside ambient temperature sensor behind the grille by the horn.
Old Oct 28, 2010 | 08:15 PM
lux97Max's Avatar
thanks for the advice, but really i don't need all of that i just want the basics like auto, econ temperature change up and down, defroster for the front and back, and the mode change that's it, just like the 97, i just want to do it for looks i like the 99's better than the 97 ones.
Old Oct 29, 2010 | 02:47 PM
This is incorrect. If you shine a flashlight into the 97 ECC, the AMB is there. All he needs is a button for the AMB function.
I believe you misunderstood the question. He already has an ECC, just not the more modern 98-99 version.
Old Oct 29, 2010 | 03:00 PM
DennisMik's Avatar
Yeah, had a brain fart. I missed the detail that the car all ready had auto climate control. But I don't understand your reference to ECC.
Old Oct 29, 2010 | 03:31 PM
ECC = Electronic Climate Control. Same thing as ACC (auto climate control)
I call it ECC because I think that's how the FSM calls it.
Old Oct 29, 2010 | 04:43 PM
lux97Max's Avatar
thanks wizard . so it is possible then to keep the features the same and have the amb button in the 1997?
Old Oct 29, 2010 | 04:53 PM
lux97Max's Avatar
and swap m old 97 modile and have the newer 1999 acc module?
Old Oct 29, 2010 | 07:11 PM
yes, but adding the amb button and making it fully functional like OEM is the tricky part. Getting just the right spring, mounting it...I looked at this option, and it seemed like a nightmare. In my 98, I just bought a 99 ECC and swapped.
I'm not 1000% sure. I'd a)compare the wiring in the 97 FSM vs. the 99 FSM and b) take out your climate control and take a pic of the back. I can take a pic of my spare 99 ECC and we can compare if you wish...
Old Oct 29, 2010 | 07:44 PM
lux97Max's Avatar
ok no problem i can do that, the 99 module has alot more wires tho, the 1997 module only has a few, but yea ill take a pic first thing tomorrow mourining is that kool with u?
Old Oct 29, 2010 | 07:46 PM
lux97Max's Avatar
have you done this swap before?
Old Oct 30, 2010 | 12:37 AM
Pics as promised. This is a 99 ECC.
Not the kind of swap you're talking about.
Old Nov 3, 2010 | 09:48 PM
Well, what's the verdict?
Old Nov 8, 2010 | 10:55 AM
lux97Max's Avatar
sup wiz i got everything out ima post pics up tonight no doubt
Old Nov 21, 2010 | 01:34 PM
lux97Max's Avatar
i have both versions of ecc the one with no amb button and the one with the amb button
Old Nov 21, 2010 | 01:38 PM
lux97Max's Avatar
what will i need to do to make the amb button function?
Old Nov 21, 2010 | 04:45 PM
DennisMik's Avatar
You probably need to get the sensor that is behind the grill by the horns and you need to check if the wires for this function are in the harness. My 97 that has manual controls has a connector taped to the harness behind the strut that the horns mount on, so maybe the wiring is there.
Old Nov 21, 2010 | 05:29 PM
Bonka's Avatar
Schnell kaputt
AMB button came in '99 Maximas and '98-99 I30s. You can ONLY add the AMB button to the '98 Maxima ACC units as the function is there already it just lacks the button. You can either find the button (new is discontinued, however) with the plastic attachment mount in the back to hold it into the unit or as a few members have done, drill a hole where the button would be, buy a piece of eraser pen, run it through the hole and glue the other end down to the board. There are posts about this just search.
Old Nov 22, 2010 | 07:09 AM
lux97Max's Avatar
im having my boy look at my car today hes really smart with electronic wiring for car stuff hell let me know today if its possible to do
mikeg75
Nov 30, 2015 05:12 PM
Max139617
Sep 29, 2015 06:44 PM
Bonka
Sep 14, 2015 11:18 PM
EdRomo86
Sep 12, 2015 07:49 PM
