My car lights die when i press the gas
Old Nov 2, 2010 | 05:09 AM
Dubb1234's Avatar
When i press the gas the dash lights radio ac heat and the outside lights go out but the car is still running fine. When i coast in neutral everything is fine The car doesnt have any problems when i go in reverse either. Can anyone make any suggestions
Old Nov 2, 2010 | 06:54 AM
tigersharkdude's Avatar
Im going to guess it either the battery or the alt.
Seems like the lights work fine and the car idles fine, but when you press the gas (cause an electrical pull) the lights die so the car gets the power it needs
Old Nov 2, 2010 | 06:58 AM
pavelsmax's Avatar
I would venture to guess the same thing. You can have your starting and charging system tested for free at autozone. They will be able to tell you if you have a bad batt. or alt.
Old Nov 2, 2010 | 07:03 AM
Nopike's Avatar
Check that your battery terminal connections are clean and tight.
Old Nov 2, 2010 | 11:00 AM
DennisMik's Avatar
This may be a stretch, but check and make sure that a wire harness hasn't gotten tangled with the gas pedal.
Old Nov 3, 2010 | 02:41 PM
Dubb1234's Avatar
Problem Solved
Hey yea i finally fixed it .....it was in my charging system the ground to the alternator was off therefor it was causing my battery to overcharge......
Old Nov 3, 2010 | 05:02 PM
Trapstars's Avatar
sounds like a nissan.lol
Lakersallday24
Jun 16, 2019 01:35 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Samedi
Aug 13, 2015 04:05 PM
Maxboy23
Aug 11, 2015 11:59 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
