weapon-r dragon intake.......
Old Nov 8, 2010 | 03:37 PM
max ride 41's Avatar
curious to know if any of you guys have used this or heard of these guys. i dont have a cai as of yet, and am open to discussion and suggestions on this. im wondering if at 210,000 miles on maxy if its gonna hurt or help the engine?? thoughts?? thanks in advance http://cgi.ebay.com/ebaymotors/Nissa...Q5fAccessories
Old Nov 8, 2010 | 03:39 PM
5150pa's Avatar
It's a short ram, Not a CAI.
Also, the filter is foam. You could look up the pro/con vs paper or oil if you want.
It's mostly for sound, and for my money the Weapon-R secret weapon sounds a lot nicer.
Pretty sure you can get it off CustomMaxima for cheaper
Old Nov 8, 2010 | 03:44 PM
ya, i knew it was short ram. i didnt know even with all the threads on this allready if it was ok to put on a high mileage max. and, of course i dont want to spend that kind of $$$$ on this until im sure i got the right set up for the ride. not looking to make max any louder, just want to help performace a bit.
aackshun's Avatar
Too much moneyz, look for any SRI piping and buy a well known/good cone filter if you're looking for the sound and easy maintenance.
FWIW I'm less than 30k behind you in mileage.
Old Nov 8, 2010 | 03:50 PM
link me up man, dont want too loud
Old Nov 8, 2010 | 03:51 PM
5150pa's Avatar
Ah well, In your OP you said something about CAI. Was just making sure.
Regardless of what brand SRI you buy, it WILL be louder, and depending on which posts you read, will either perform worse or have negligible gains over the stock setup. (Quick search will reveal the great debate)
Dave H.'s Avatar
Do not spend that much money for an intake. You're better off getting something like this and as stated above, get a good filter.
http://cgi.ebay.com/ebaymotors/1995-...item33621b4ae7
(and that is a picture of my car, w/o permission)
Age probably won't matter. It's not going to give much power gain, only a great sound.
Old Nov 8, 2010 | 03:55 PM
5150pa's Avatar
Originally Posted by Dave H.;7806010
[URL="http://cgi.ebay.com/ebaymotors/1995-1999-Nissan-Maxima-3-0L-V6-Cold-Air-Intake-/220689287911?pt=Motors_Car_Truck_Parts_Accessories &fits=Year%3A1995%7CModel%3AMaxima&hash=item336 21b 4ae7"
http://cgi.ebay.com/ebaymotors/1995-1999-Nissan-Maxima-3-0L-V6-Cold-Air-Intake-/220689287911?pt=Motors_Car_Truck_Parts_Accessories &fits=Year%3A1995|Model%3AMaxima&hash=item33621b4a e7[/URL]
improve better air flow, gives a deeper thortty sound
Hell yea, Thortty.
Old Nov 8, 2010 | 04:19 PM
Mr. Brett's Avatar
Build your own...much cheaper.
MAF adapter from eBay ($10-15)
4" in length Aluminum pipe ($7-12)
AEM Dryflow filter ($45)
Various clamps ($5)
All-in-all, you're looking at around $80 to get a nice setup. You don't even have to get the Dryflow if you're wanting to save money. I just suggested it because it can help prevent fouling your MAF.
If you're looking for more performance gains, and a little quieter sound, grab a velocity stack. Blox sells them for around $20. The velocity stack actually made my intake quieter. It doesn't whistle under load like it did with just a filter in place.
Old Nov 8, 2010 | 04:43 PM
That's what you need, you won't lose any low end with a true CAI. I have the same and love it.
Old Nov 8, 2010 | 05:21 PM
xtremepb0's Avatar
Quote: You don't even have to get the Dryflow if you're wanting to save money.
does the bypass cover your talking about take away any of the noise from the intake or is it virtually unoticable and just protects the intake from water?
Old Nov 8, 2010 | 05:24 PM
what happens to the resonator and all that plastic sitting over the rad and $hit? it all comes off when you do the cai?? ( im guessin ) dave h., does the 1 end of the cai go somewhere neatley in the wheel well?? where's the cone?
Old Nov 8, 2010 | 05:32 PM
what happens to the resonator and all that plastic sitting over the rad and $hit? it all comes off when you do the cai?? dave h., does the 1 end of the cai go somewhere neatley in the wheel well?? where's the cone?
The entire stock intake is removed. CAI goes under the fuse box into the fender. Filter sits behind where your foglight would be, in front of the fender splash shield.
Old Nov 8, 2010 | 05:40 PM
that wouldnt be good, my splash guard on that side of the car has been missing for years. lol, guess i need 1 of those too. is that the best set up, or is there easier more effective ways for install?
xtremepb0's Avatar
does this mean you have to completely remove your foglights? also can you install it without taking any of the body off of the car? not trying to jack the OP's thread just felt that it wasnt necassary to create a new thread for this question
Old Nov 8, 2010 | 05:47 PM
Mr. Brett's Avatar
Bypass cover?
You mean the velocity stack?
No, it sits between the intake piping and the filter. It's designed to provide more gains by smoothing out the airflow as it enters the intake.
It sort of looks like the end of a trumpet.
^ That's the VS.
And that's the theory behind it.
It's not actually designed to reduce noise. It just happens as a result of there being less turbulent air in the intake.
Old Nov 8, 2010 | 06:18 PM
Dave H.'s Avatar
With a true cold air intake, you'll have to cut a ~3" hole next to your battery tray. Not too hard, but a little scary making a permanent cut. There's a template around for guidance. You'll need to remove the battery, battery tray, temporarily move the fuse box out of the way, and make room for drilling the hole.
You won't have to remove you foglight to install, but you will need to remove splash shield under the driver's side bumper (one screw and a 10mm? bolt), and the bumper lenses to see what you're doing. Some people may have removed wheel well lining instead.
Old Nov 8, 2010 | 06:43 PM
xtremepb0's Avatar
Is there any way to keep the filter sort of flush up top with the engine so you don't have to remove anything or cut. Or do I just have to suck it up and cut the hole for it?
Old Nov 8, 2010 | 07:03 PM
aackshun's Avatar
http://cgi.ebay.com/ebaymotors/1998-...ht_4595wt_1165
Sound preference is sooo subjective.
Get that and a respectable filter and call it a day, I personally don't take stock in an intake that requires 3ft+ of tubing, but that's just my personal feeling towards it.
I paid $20 for my Bomz SRI from ebay awhile back, I doubt you'd find a better deal than what i paid for.
jholley's Avatar
I just baught that setup for $5 less:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=360313955954&ssPageNam e=ADME:X:RTQ:MOTORS:1123
It's the exact same setup sold by the same seller for only $39.99
To prevent hydrolocking what bypass valve should I add to this 3" setup?
Old Nov 8, 2010 | 07:15 PM
Mr. Brett's Avatar
Originally Posted by jholley
Save $5 and buy this:
This one.
Old Nov 8, 2010 | 07:44 PM
rolis12's Avatar
I put a K&N 3" cone with a MAF adapter and removed the snorkel and airbox completely. i'm a noobie (sorry in advance) and did this on a whim. im interested in any constructive opinions and suggestions. i have pics in my album.
video of it:
http://www.youtube.com/watch?v=nrU2lUPDxDs
Old Nov 8, 2010 | 09:24 PM
cartman854's Avatar
I ♥ Weapon R look. Thats about it.
Old Nov 8, 2010 | 09:47 PM
video of it:
lol, 1 post in over 3 years. sounds pretty stock to me
Old Nov 9, 2010 | 09:59 AM
rolis12's Avatar
Yea Ive been lagging. Till now, for me it's been only strick up keep and what needs to be done on Maxi and Now that she's running nice i'm ready for mods. Anyway...
I took off the snorkel and there was a sensor near the end of it in a hole with a gromit. I put it on the MAF adapter between the filter and MAF.
My question, is that the IATS and is it ok where I put it.
Thanks for any help sorry to jack this but I can't start one yet
Old Nov 9, 2010 | 03:50 PM
5150pa's Avatar
Searching around myself wondering the same thing, I've found people just tie it up somewhere near the intake. Seemed to not really matter
Old Nov 9, 2010 | 04:59 PM
shiloh51933's Avatar
A K&N filter in the stock air box works good, those short ram air intakes w/cone filters don't really do anything but make noise. Unless your gonna fab up your own CAI just use a K&N filter in stock box.
Old Nov 9, 2010 | 05:11 PM
5150pa's Avatar
I think most people buying these want the noise
Old Nov 9, 2010 | 08:02 PM
rolis12's Avatar
For sure its just for the sound, at least for me and if you take it easy on the gas then its as quiet as a whistle up to 3500rpm. i like the sleeper. im sure ill get annoyed with it sooner or later but its a start for me and i still have all the stock set up.
this is how it sounds on the road...i like it
http://www.youtube.com/watch?v=n8-5v2m-moY
Old Nov 9, 2010 | 08:13 PM
AlexxSCM's Avatar
move the battery and start drilling....
Old Nov 9, 2010 | 08:15 PM
Mr. Brett's Avatar
Something about the VQ sound with a CAI/SRI and headers, testpipe and stock catback at WOT is just... to me.
It's addicting. Even my buddy who's a Honda fanatic told me he loved the sound of the VQ from inside the cabin when we went for a drive.
Old Nov 9, 2010 | 08:18 PM
you owe me 5.00 dollas for jackin my thread. not bad, im guessin all stock except for the intake? pics???
Old Nov 9, 2010 | 08:21 PM
AlexxSCM's Avatar
huh??
Old Nov 9, 2010 | 08:23 PM
Mr. Brett's Avatar
Wait, wat?
Old Nov 9, 2010 | 08:24 PM
AlexxSCM's Avatar
im outta here........
Old Nov 9, 2010 | 08:40 PM
rolis12's Avatar
yea all stock. ive never posted before till now because ive only used the site as reference for maintenance and now im ready for some mods. this was super easy and i had $50. This place is awesome and i hope to start posting some good stuff as i go.
And starting my own threads :P
i have pictures in my member profile album
Old Nov 9, 2010 | 08:41 PM
Originally Posted by SLCPunk267
Wait, wat?
i was talkin to rolis12 guys...
Old Nov 10, 2010 | 03:27 PM
luke95gxe's Avatar
yo max ride i have had the weapon type r dragon ram intake wasnt very impressed it was very throaty but the plastics on the air filter sux the chrome paint chipped and plastic broke i have also had the cai through the fender well love that till i got in a front end accident an mangled it so im using the weapon r mid pipe with another filter
if you ask me go cai ill see if i cant get a pic of the weapon r air filter all jacked up
Old Nov 10, 2010 | 03:47 PM
supurman0805's Avatar
CAI are just for the noise! GOOD K&N FILTER WILL DO YOU JUSTICE!
Old Nov 10, 2010 | 03:50 PM
luke95gxe's Avatar
cold air = better running engine
