Need help identifying steering issue.
The issue: Steering the wheel is hard as hell when starting up the car in the morning (cold temp); however, steering gets easier/better when car is warmed up. Also, I’m leaking power steering fluid but can’t find the damn leak.
Has anyone else experienced this problem on their Max?
Please help!
Please help!
You oil leak has a good chance of being the high pressure power steering hose. Happens to many people, unfortunately.
The hard steering could be a belt problem. Maybe adjusting the tension will fix you up, maybe you might have to replace it. Also, it might be getting oil on it from the leak which will just add to your problem.
By the way, I hope you are adding automatic transmission fluid to your power steering reservoir and NOT power steering fluid. That's the way Nissan made it.
Please help!
Please help!
I'm thinking that the fluid is not distributing properly? Could be PS pump?
Also, i'm having trouble locating this "high pressure steering hose" you speak of. Got any pics?
Unless another org. member can tell me their true experience with PS pumps, the aftermarket ones are no good. Keeps too much noise...only way is to go OEM which I am saving my money for.
worldwiderecognized
Sep 30, 2015 01:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
