Dashboard Removal, car wont start now...
Old Dec 9, 2010 | 10:53 AM
  #41
Nopike's Avatar
Remove your fuseable links one at a time and check for power to all of them. You should have power at one of the two terminals on all of them.
Old Dec 9, 2010 | 11:15 AM
  #42
SleepyMax1's Avatar
Did it... checked with the test light and all terminals are getting power.. the fuses on the left side of the box get power from the terminal on the left, and the fuses on the right side of the box, get power from the terminal on the right... (heck I even found out the car had a horn all this time)
Old Dec 9, 2010 | 12:06 PM
  #43
Nopike's Avatar
Power goes from 30 amp fusble link "h" to the ignition switch. Horn does not need assy or ign relay to work. From the ignition switch it provides power to the assy and ign relay.
Old Dec 9, 2010 | 12:21 PM
  #44
Nopike's Avatar
Make sure you have power at the white with purple stripe wire at the ignition switch. From there it goes to the assy and ign relays when you turn the ignition switch.
When in assy position should have power at the white with blue stripe wire and in the ign postion should have power at the Black with red stripe wire at the ignition switch. This turns on your assy and ign relays. Make sure to double check your connections for these wires.
If there would be anyplace where I would say a wrong connection could cause this problem it would be at the ignition switch but you probably did not touch that during your dash removal?
Old Dec 9, 2010 | 02:25 PM
  #45
Nopike's Avatar
Does you clock work? If not check for power at ther locations listed in ^ post. If the clock works check items listed below.
Did you disconnect any solid black ground wires that may have been running to the underdash fusebox? There is a ground wire that attaches to the body near the drivers side door near the bottom. It would probably run to a screw that attaches the black ground wire to the body.
Do you have any solid black ground wires that run to the body of the vehicle that may have been removed when you took the dash and such off?
If you cannot find any loose ground wires try running a ground wire from the body of the car to the black wire that goes to the fuse box.
I sent you a PM.
Old Dec 9, 2010 | 10:07 PM
  #46
styliztik's Avatar
have we checked the battery? it might have enough juice to run all these accessories, but not enough to start. and only using more and more accessories with out the alternator charging it, only kills it more.
Old Dec 9, 2010 | 10:28 PM
  #47
SleepyMax1's Avatar
The battery is good, even took it to get it charged again... due to all the cranking we were doing a few days earlier.
Old Dec 9, 2010 | 10:54 PM
  #48
styliztik's Avatar
Okay. just checking because I don't know about you guys, but my battery will start to die after playing the stereo for 10 mins.. if that.
Old Dec 12, 2010 | 10:19 AM
  #49
SleepyMax1's Avatar
Hey Walley,
The black ground that your talking about is still there... screwed into the body. I even hooked up my test light to that ground thinking "oh well here's a ground, let me use it" still no change. I'll try to run another ground and see what happens...
I appreciate the help everyone... thanks
I sent you a PM.
Old Dec 12, 2010 | 09:03 PM
  #50
Nopike's Avatar
I think you may be having an issue from somebody trying to hook up an audio system or something and messing up the wiring.
We are going to try and get the assy relay working by isolating it from the other circuits.
1) Install a good assy relay
2) Remove Fuse #21 (10A) ------- Audio and clock The fuse numbers are molded into the underdash fuse box. You can see them if you look closely.
3) Now turn the ignition switch and see if the assy and ignition relays work normally. If they do your car should start.
If you are still having a problem try removing these fuses from the underdash fusebox also.
Remove Fuse #2 & #3 (both 15Amp) ---- Blower Motor
# 6 (15A) -----Cigar
# 7 (10A) ----- DEF and Mirror
#19 (7.5A) ----- Various inc theft (this fuse may be required to actually start the car)
#20 (20A) ------ Wipers
#36 (7.5A) ------ Phone
Except for maybe the theft you do not need any of those functions for your car to work.
After you have removed all those fuses (see if the assy and ignition relays work normally. If they do your car should start.
Once the assy and ignition relays work normally you can start reinstalling the fuses one at a time and see if any of those circuit causes a problem.
If I had to put money on it I would expect the audio circuit to be an issue. Thats the one everyone screws with.
Old Dec 12, 2010 | 11:39 PM
  #51
98MaximaDriver's Avatar
Nopike you need a Flattr button under your username !
I was following this thread cause i was considering buying another 4th gen that needs a tan to black interior swap, and this thread has me thinking im way over my head!
Good Luck SleepyMax1
Old Dec 12, 2010 | 11:43 PM
  #52
TheArtist's Avatar
something happened when he took everything off. it is not that hard to remove our dash and swap it out with another. he is just having bad luck with eveything. i did it and had no problems with my wiring, everything works for me
Old Dec 13, 2010 | 06:55 AM
  #53
Nopike's Avatar
I think the car may have had an issue before the dash was removed. If I were you I would not worry about it. Very unlikely you will have issues like this.
Old Dec 13, 2010 | 02:46 PM
  #54
SleepyMax1's Avatar
I think the car may ahve had an issue before the dash was removed. If I were you I would not worry about it. Very unlikely you will have issues like this.
Agreed... I've had issues "electrical" wise, it was only a matter of time, before something major would happened. The Dashboard wasnt as hard as I thought... just take your time...
Old Dec 14, 2010 | 05:59 PM
  #55
Oh ok.
I was a lil intimidated reading this thread.. I get to see the car tomorrow so well see how it goes.
good luck again SleepyMax1
Maxima.org FTW!!
Old Dec 14, 2010 | 06:03 PM
  #56
colombianmaxima's Avatar
This may sound stupid to you guys. But how do you take off the whole dashboard
  #57
Like how hard is it todo and how long it take
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
