Upgrade harness or full relay install?
i am running 80/100w 9004 bulbs for my headlights, i have been running them for months and the other day i was on backroads for a while and had the high beams on well i burned up the ground wire and need to replace the harness.(it didn't happen all at once still works if i move it)
the harness is an aftermarket autozone one and it said high temp but it was from autozone. (for $6)
the car seems to be able to provide the power no prob its right at the socket that i have a problem.
if i install a ceramic socket or a good high temp with this be enough?
i was thinking this:
http://www.amazon.co.uk/Ceramic-Bulb.../dp/B003S590L4
or
http://www.amazon.com/gp/product/B00...KX0DER&pf_rd_s
or if i really needed this:
http://www.putco.com/products.cfm?ac...4-9273fe4298ef
or
These have worked great for me in the past:
http://cgi.ebay.com/2-x-Wiring-Harne...item3a60cdd60d
The wires are lower gauge than stock and are nicely insulated, plus they're cheap and plug and play (wires don't have to be spliced).
I ran that set-up for a while, then upgraded to a 35W bi-xenon HID kit which came with the relay wiring harness and will be running a 55W HID kit for my retro with a custom relay wiring harness that I made which will be partially using the upgraded harness I listed in my other post.
You should be fine.
**UPDATE**
since the install i have replaced the sockets or wire leads a couple more times because they burn up! This is with the ceramic socket, (its fine the wire is not)
so i finally decided to bite the bullet and install a full harness with relay!!!
omg, im an ***. i should have done this from the start no more melting wires and even brighter lights!
i went with this guy:
http://suvlights.com/product_info.php?products_id=112
they were great fast shipping its pretty well consructed for the price. any failures i will report back but i think i would have seen it by now!
**UPDATE**
Yea. I was thinkin about making my own but for the price why? It's good quality it comes with everything so why not. With the cost of copper and the ends and the relays it adds up fast they were only $50. I got it in a couple days too!
vingodine
45
May 21, 2016 12:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Viralkill
Aug 17, 2015 10:54 AM
