infinit q4 engine
Old Dec 18, 2010 | 12:18 PM
K31J1m0N's Avatar
infinit q4 engine
quick question. can the infinit qx4 3.5 fit into the maxima or would the intake manifold have to be swapped out...someone let me kno cuz i found a really good deal on one
Old Dec 18, 2010 | 02:50 PM
Crusher103's Avatar
what the hell is a q4?
Old Dec 18, 2010 | 02:53 PM
chrome91's Avatar
are you talking about the Infiniti Qx4 SUV or what?
Old Dec 18, 2010 | 03:54 PM
Mr.A32ftw's Avatar
What the hell is a maximaor?
Old Dec 18, 2010 | 06:20 PM
K31J1m0N's Avatar
wow wut else would a q4 for be, yes a qx4 and come on man im pretty sure youve ran into typos before...the "maximaor was suppose to be "maxima"
Old Dec 18, 2010 | 06:23 PM
I doubt it's been done..
Old Dec 18, 2010 | 06:36 PM
K31J1m0N's Avatar
well from looking at it the head and block is the same...its just the intake manifold that looks different...ill tell u what... ill try it out for the org and see if i can get it working...until then if somebody has any idea let me know
Old Dec 18, 2010 | 06:39 PM
mpvibes's Avatar
No, Qx4 is a VQ35VHR (rear wheel drive) with dual intake, its the same engine as the 350Z. U need a VQ35DE, that motor can go into a maxima.
Old Dec 18, 2010 | 06:49 PM
Crusher103's Avatar
What the hell is a VQ35VHR?
How the hell are you people coming up with this ****?
Old Dec 18, 2010 | 06:50 PM
K31J1m0N's Avatar
guess im gonna have to add and subtract some stuff since the motor was givin to me...
Old Dec 18, 2010 | 06:59 PM
Crusher103's Avatar
there is no such thing as a VQ35VHR.
The Qx4 is a pathfinder in fancy sheet metal. it uses a RWD based VQ(its a VQ35DE), those VQs dont fit with out serious modifications into these cars, and its not worth it even if u did get it for free, sell it to somebody with a 240 and go buy a FWD based VQ35
/thread.
Old Dec 18, 2010 | 07:02 PM
Even if u did get it for free, sell it to somebody with a 240 and go buy a FWD based VQ35
/thread.
QFT
Old Dec 18, 2010 | 07:49 PM
maxfever1987's Avatar
/thread.
so you have never heard of the 7th gens being a vq35hr motor? high rev?
the hr motors exist, read up on it and find out
Old Dec 18, 2010 | 08:06 PM
chrome91's Avatar
Old Dec 18, 2010 | 08:24 PM
FallenOne's Avatar
Yes, a VQ35HR exists but ive never heard of a VQ35VHR
Unless they've given them variable valve timing and high rev together.
Old Dec 18, 2010 | 10:56 PM
Crusher103's Avatar
..... not another one. Yea you keep thinking the 7th gen has a VQ35HR, see how far that gets you.
Old Dec 18, 2010 | 11:02 PM
FallenOne's Avatar
Old Dec 18, 2010 | 11:18 PM
defiance's Avatar
What the hell is a 240 Crusher?
Old Dec 18, 2010 | 11:27 PM
dame_dashvq30's Avatar
and your wrong it does not have dual intakes.. the qx4 is the same as the pathfinder ..
Old Dec 18, 2010 | 11:40 PM
:metalmax:
IBTL.
Old Dec 18, 2010 | 11:50 PM
Leo_Koneval's Avatar
  • 1 DE series
  • 2 DD series
  • 3 HR series
  • 4 VHR series
    VQ37VHR
    It was the first production engine from Nissan using VVEL. It has an increased compression ratio of 11.0:1, with 3,696 cc (225.5 cu in) displacement (95.5mm bore and 86mm stroke), while redline remains at 7600RPMs. It is rated at 337 PS (248 kW; 332 hp) at 7,000rpm and 37.2 kg·m (365 N·m; 269 ft·lbf) at 5200rpm. Although the engine gains only 0.2 kg·m (2 N·m; 1 ft·lbf) peak torque over the VQ35HR and this higher torque arrives at 5200 rpm vs. 4800 in the VQ35HR, the torque curve itself is improved and flattened via VVEL variable valve timing for better throttle response and low rpm torque. The VQ37VHR engine has been touted by car magazines and reviewers as an improvement over the VQ35HR engine mostly adding much refinement and smoother engine operation, especially at high rpm where the VQ35HR engine was frequently criticized for NVH and sounding strained, harsh and loud.
Old Dec 18, 2010 | 11:52 PM
Oh and just one more thing...
Allow me to answer some questions:
-2002-Current Maxima has VQ35DE
-Current Skylines, Infinities, 370Z has VQ37VHR
-2008 Skylines, Infinities and 2009 350Z has VQ35HR
Old Dec 18, 2010 | 11:55 PM
tsheffler's Avatar
240sx?? lol thats my guess
Old Dec 19, 2010 | 12:27 AM
j-dawg's Avatar
He's asking for the stability characteristics of the engine. Poles in quadrant IV ("q4") are positive and complex (with a conjugate pole in Q1), indicating an unstable oscillating system. It is therefore "infinit" in that settling time (ts = 4.6/zwn, 1% settling criterion) and steady-state error (ess = lim(s->0) (R(s)*s*G(s)) are undefined. Our attempts at determining maximum overshoot ("fit into the maxima": Mp = exp((-z*pi)/sqrt(1 - z^2))) will not succeed.
Thus, one cannot swap a QX4 engine into a Maxima. Next.
Old Dec 19, 2010 | 12:57 AM
MoncefA33's Avatar
7th gens don't have HR anything. It's a DE.
This. VHR doesn't exist in the 3.5L version. 37VHR is the only one, it has VVEL.
The 35HR only comes in the 350Z.
The Qx4/PF uses a RWD VQ35DE. Mounting locations on the block are different. There are stickies with this information in the All Motor forum actually.
There's nothing to gain, power-wise, from a 3.5 swap out of a Qx4/Pathfinder.
Old Dec 19, 2010 | 05:13 AM
tigersharkdude's Avatar
Take your VQ35HR comments elsewhere
Old Dec 19, 2010 | 06:22 AM
essential1's Avatar
My axles cry for mercy...
Ahh... The 4th gen section...
http://forums.maxima.org/all-motor/5...s-lengthy.html
Different heads DO NOT magically transform a standard DE into an HR by the way.
Old Dec 19, 2010 | 06:27 AM
HomerMAC's Avatar
Donating i30 Owner
... ANY swap is possible, with the right amount of funds. .
... You can have all sorts of variants of engines as well. The BLOCK is the foundation from which you build up.
There is currently a VQ38 or vq39 (forget which) / 6speed 4thgen running around in NY. there are a few vq32s. Once you have the block, you can go from there for displacement, sleeved etc. blah blah blah. These are hybrid or built engines. (why people spend that kind of $$ on the max... i dont know... but hey to each their own)
I say; if you have to ask "can a swap be done?", then your probably not at the point of being able to do swap. Thus read... read.. and read some more. Its much better to find the answeres to these questions on your own than to hear a bunch of guys/gals smart coments/confusion on line.
Thats my smart comment... lol.
Old Dec 19, 2010 | 06:36 AM
essential1's Avatar
This is the most important thing i've read on this thread.
Old Dec 19, 2010 | 08:22 AM
Product_Of_Korea's Avatar
Old Dec 19, 2010 | 09:37 AM
Mr. Brett's Avatar
^ That.
Old Dec 19, 2010 | 09:39 AM
Mr. Brett's Avatar
By the way, Cef...the 4th gen G35s also have the 35HR.
Old Dec 19, 2010 | 10:17 AM
I thought this was a maxima WTF?
Old Dec 19, 2010 | 10:33 AM
tedo007's Avatar
faster than you think
guy with less than 100 post trying to argue with guy that has over 35,000 post
LMAO
Old Dec 19, 2010 | 11:03 AM
Nealoc187's Avatar
SLOW
Jesus
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
