Weird ticking sound from around timing chain cover
Old Dec 21, 2010 | 11:47 AM
tigersharkdude's Avatar
Okay so I am hearing this weird ticking/staticy sound coming from the timing chain cover area near the front valve cover. It is a very light sound and can not be heard inside the car UNTIL I get up to around 55mph at that point I can hear the sound in the cabin. IMHO when you can hear it in the cabin it sounds like a static coming from the audio but Ive ruled out audio since it can only be heard over 50pmh in the cabin.
Anybody have any ideas? Ive searched and read a few things such as timing chain tensioner, TC guides, possible bad gas (just filled up with 93 at a different place, so I will know within a few days if thats the problem)
Thanks peeps
Also the sound has no rhythm when it can be heard in the cabin. I cant tell under the hood as it is fairly faint
Old Dec 21, 2010 | 12:21 PM
njmaxseltd's Avatar
Remove the drive belts, start the car.
If the noise is still there it's within the timing assy.
If the noise is gone it's either an accessory device or a bad belt.
Old Dec 21, 2010 | 12:48 PM
If it's a TC guide or tensioner would it be fine to drive on it for a while?
Old Dec 21, 2010 | 10:13 PM
defiance's Avatar
You shoudnt have a problem driving it for a while your just going to
hear the timing chain. Whats the mileage on your Maxima ?
Old Dec 22, 2010 | 07:16 AM
cashoit's Avatar
you sure its not wheel bearing? Ususally after the oil is warm noise "chain rattle" goes away.
Old Feb 17, 2011 | 08:50 AM
max ride 41's Avatar
my timing chain has made noise for 6 years now. it is getting louder, i know ill have to replace it soon though. or ill just do the main guide and water pump.
Old Feb 17, 2011 | 09:54 AM
mightyMax95's Avatar
http://www.youtube.com/watch?v=Tx1XIm6q4r4
Old Feb 17, 2011 | 11:22 AM
skim35's Avatar
My guess is the valve noise - they are adjustable but you would need a special tool to take the valve shims out.
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Jcof88
Aug 3, 2015 10:43 PM
