which swap should i do? de or dek?
Old Dec 24, 2010 | 07:51 PM
tsheffler's Avatar
ok so...im at 240000 miles and the motor is still running fairly strong...my power steering pump is going out, and the engine is getting a lil louder than it used to so...im looking to swap my engine but done know what to go with. im gonna do either just a younger engine or go to a dek....which would yall go with? i dont have the money to go witha vq35...so thats pretty much outta the question. im happy with the way the vq30 performs but just want something younger...
i plan on putting the new motor on a stand and changing the timing chain, and necessary gaskets...what else should i change while the motors out....im thnkin polly pro mounts as well....?? any imput would be great.
last but not least. wheree should i get an engine...i would rather find someone on the org to buy from vrs a junk yard...although that is not totally out of the equation lol thanks!
tim
Old Dec 24, 2010 | 08:00 PM
vqmaxman's Avatar
If your going to drop in the DEK than your pretty much gonna have to change the fuel rails and coils to 5th gens and the manifolds and some other things that I can't think of right know. But the main point here is that your gonna have to change up the settings if your gonna drop in the DEK vs the reg vq30de that you already have. It will probally be better and cheap to go with the DE.
Old Dec 24, 2010 | 08:02 PM
tsheffler's Avatar
agreed, if i were to go witha dek, i would just get everything i need from the junkyard (if thats where i got it) so i could come home and basically just drop it in, but i know it isnt that easy haha so im kinda leaning towards a younger de then....but i still want more feedback plz
Old Dec 24, 2010 | 08:25 PM
essential1's Avatar
My axles cry for mercy...
Since you dont seem to be doing this for a power benefit, just get whatever you can with lower miles, but at a good cost. There is nothing hard about a dek swap really. And if you find a dek for a better deal than a DE, but you dont wanna mess around with making the 00vi work properly, you can just swap your old DE manifolds and fuel rails onto the dek. This will make the swap basically plug and play. Then you can sell a complete 00VI swap setup for cash back in your pocket.
False. Stock 4th gen coils work fine. I'm currently running them in my dek and so is many other locals with dek/00VI setups.
Old Dec 24, 2010 | 08:47 PM
tsheffler's Avatar
thanks!, and i am in it for the power end of it....but dont wanna spend a ton of money, or i would do the 3.5 lol. i am kinda interested in the 6mt eventually but thats down the line....probable after maxus...but my car will hvae a new engine, and body work/paint job by maxus! so to do a dek, would i need the 00-01 ecu? im 5mt right now so if i did go dek, would i have to get a new clutch again?
Old Dec 24, 2010 | 09:01 PM
vqmaxman's Avatar
I don't think your gonna have to drop the 00-01 ECU in unless your droping the 00-01 engine in. Basicily your just doing cam work on the top of your engine DE to a DEK. The 3.5 swap your gonna throw more money than just doing the DEK because, This where your gonna have to change up the ECU and the wire harness and customize a way to make your motor mounts fit the 3.5 L engine to make run right. I don't think your gonna have to change the clutch just because of the DEK. If your clutch is slipping and the car is responding badly to your shifting that is when your gonna have to change the clutch.
Old Dec 25, 2010 | 05:34 AM
essential1's Avatar
No ecu change is needed for the dek swap or the 3.5 swap. The dek swap is virtually a direct swap. The 3.5 swap is not as hard as people make it either. And other than the cost of the motor being a little more, its not that much more (shop around and you might score one for less than a 3.0) expensive either. Take your time and read the all motor section. All this info has been beaten to death and its all over the stickies. I'll even go the extra mile and link you to it.
http://forums.maxima.org/all-motor/4...swap-info.html
Dude, not to be rude, but what in the hell are you talking about? Stop typing out your rear end and start reading. This info is all over the place. Again, i'm not trying to be rude, but everything you have said so far couldnt be anymore outragously wrong.
Old Dec 25, 2010 | 12:21 PM
tsheffler's Avatar
thankyou! ill be doing my reasearch
Old Dec 25, 2010 | 08:39 PM
vqmaxman's Avatar
DUde i am not talking out of me **** I know what I am talking about. I think your being rude and picking on people.
If, IIRC I was reading on some of the things here and when they were talking about swaping to a 3.5L the car has to have some changes with the ECU and the harness wires to get it running right and to give it a correct fuel map and so on.
Old Dec 25, 2010 | 09:22 PM
schmellyfart's Avatar
Dude, he's not picking on you. I was going to correct your post about the motor mounts, 00 ecu, etc but decided to keep my mouth shut because I didn't feel like typing out the (IMO) basic information on these swaps. Especially when you say you know what your talking about. The correct information can easily found from reading 3.5 and 00vi swap threads.
It seems like you have somewhat of an idea of what goes on in these swaps, yet think you know more than you actually do. I suggest you read up on these swaps and re-read what you posted in this thread. Then you should see where we're coming from.
Old Dec 26, 2010 | 05:59 AM
essential1's Avatar
I've worked on 3.5, 3.0, and dek swaps on multiple occasions. Nothing you said was correct. You sir, are talking out your **** 100%. Here, i'll take the time out my day to show you exactly where.
Show me someone who swapped a 00-001 ecu with a dek swap and I'll show you someone who wasted his time and money. Its virtually a direct swap. Only "wiring" involved is splicing the injector clips and extending the rear coilpack wires just to get some slack.
WTF? The cam specs between the DE and DEK are so close to begin with that any difference in performance increase/decrease from the cams are minimal at best. And no, your not "just doing cam work"
This is the only thing you said that even somewhat makes sense. You very well can do a complete harness and ecu swap to make the 3.5 work. This in theory is deffinately a more effective swap as far as power is concerned because you keep variable cam timing on the intake cams. I've never attempted this swap so I'm not gonna talk out my **** on the difficulty of this.
But you can do a 3.5 swap while retaining the factory harness and ecu, you lose all variable cam timing functions, but you still get an increase in power obviously. The procedure is in the stickies. And after the motor is prepped, it is basically a direct swap.
Motor mounts are the same and dont control engine function (fuel delivery, ignition, compression) so I dont know how that will make the engine "run right"
Like I said, im not being rude, but if someone in the future is considering one of these swaps and actually SEARCHES for info, I dont want them to pull up such wrong information.
Old Dec 26, 2010 | 06:17 AM
HomerMAC's Avatar
Donating i30 Owner
<<-- LIKES THIS
You can and there is a guy on the forum who did the DEK with harness swap. No cold start issue using all DEK TB & IACV. Also if you want to use the swirl valves, the harness allows the use of it.
Personally think its a waste cause your tunning options are greater for 95-98 ECUs. most people are trying to go from 99 - 01 ECU to 95/96 ECUs
Old Dec 26, 2010 | 06:45 AM
essential1's Avatar
Originally Posted by HomerMAC
<<-- LIKES THIS
Yea, the tuning options is what I was getting at like you mentioned. And cold starting isnt a problem for us in sofla. No IACV for most of us down here. Just start the car and keep your foot on the gas for about 10 seconds and it idles perfect after that. lolo
Old Dec 26, 2010 | 11:52 AM
Product_Of_Korea's Avatar
Hell i really didnt have a start up issue up here in minnesota.
Ive done multiple swaps as well and you sir make no sense.
Old Dec 26, 2010 | 12:33 PM
maxboy325's Avatar
Thank you sir. I didnt want to be that guy.
Old Dec 26, 2010 | 08:38 PM
MaximaSpd85's Avatar
imo, if you dont go dek youre making a silly decision. for one, 9 times out of 10 the dek you find will have lower mileage than a DE that you can find. two, the price difference between them is probably very minimal. at the salvage yards here, deks are 450. AND, if there is a price difference, it is made up if you sell the 00vi setup. and youll likely make a little money off of the whole deal. You can always buy a dek, and just use your usim, but why? like mentioned before, the dek is almost a direct swap, with a litttttttle wiring to be done.
Old Dec 27, 2010 | 10:59 PM
tsheffler's Avatar
ugh....so much to choose from haha:/....i do plan on going f/i eventually....does either engine have positives or negatives to f/i whether it be turbo or charge?
charge meaning supercharger* lol sorry
Old Dec 27, 2010 | 11:07 PM
MrBr3tt's Avatar
Just out of curiosity what kind of power gains do you get from the dek and the 3.5 swap? I'm thinking later on down the line once my engine starts going to just get a new engine instead of a new car. Everyone tells me no get a new car its not worth the money but I say bull I love the 4th gen Maximas I can't see myself driving anything else. Bottom line I want the Maxima I have now and more power too so if it's worth spending a little more for the power I'll be more than happy to do that.
Old Dec 28, 2010 | 11:29 AM
well, youre going to make more power in the higher rpms with the dek because of the intake manifold regardless of what you do.
Old Dec 28, 2010 | 02:46 PM
defiance's Avatar
If I had to swap engines and trannies I would go DEK aswell becuase they are newer, tend to have less miles, and dont cost much more then a DE.
Not to mention if you get the 2000VI portion of it working properly you get
a "small" gas mileage increase and 30 more HP versus the old DE.
Tsheffler I just noticed you said you drive the 5 speed version, your going to love the DEK then :]
Old Dec 28, 2010 | 07:47 PM
tsheffler's Avatar
ok so im pretty much getting from you all that if i can find a dek at a junkyard for the same price of a de then i should just suck it up and do it. I will probably use the same trans and clutch that i have now and pull as much from the junk car as i can as far as injectors, fuel rail, etc..
.im assuming from what i asked earlier that i dont need the ecu....but someone said that the newer ecu has different air/fuel....rev limiters...etc...so should i grab it if i can get it? obviously out of a 5mt... umm....what else should i get out of the car when i pull everything?
Old Dec 28, 2010 | 08:06 PM
well, i would assume if you find a dek, it will come with everything you need (injectors, fuel rail, etc) unless someone took it all apart. the only thing i would recommend you trying to find would be the fuel dampeners if they arent still attached, or a fitting for the fuel rail to adapt to your existing fuel lines. the newer ecu does not have a different rev limiter. sure, itll be optimized for the injectors etc, but still not worth trying to rewire your car. get something to tune with instead (afc, emanage, etc).
Old Dec 28, 2010 | 11:35 PM
tsheffler's Avatar
fuel adapters? like a double sided nipple so i can connect the current fuel line size to the dek? if and i think the emanagment sounds better in this situation...thanks
Old Dec 29, 2010 | 08:24 PM
well, the DE fuel rail has a barb fitting on one end for the fuel line, where as the DEK fuel rail has a fuel dampener on one end. if the fuel dampener is there u can just connect your fuel line to it, but if its not there youll have to find a way to connect your line to the fuel rail. in that case youll need some kind of fuel rail adaptor... or drill out a fuel pressure regulator and use it as an adaptor.
Old Dec 30, 2010 | 10:02 PM
tsheffler's Avatar
alright got it, ill keep an eye on it and so some research on it so i know exactly what im lookin for
Old Jan 16, 2011 | 12:25 PM
HomerMAC's Avatar
Donating i30 Owner
DEK does have coated lower friction internals + added block cooling. the exuast cams are slightly more agressive as opposed to DE that has slightly more aggressive intake cams...
I found a dek locally for $350. 74k miles. picked it up and sold the 00vi on it for $250 as entire manifold/fuel setup package becuase it was getting a custom Intake setup.
so now 100$ later a 160k + abused, boosted motor is replaced with a clean 74k motor that doesnt even have the slightest ticking of any sort. Almost makes me not want to FI it just cause its smooth. AND I GOT and i30 engine cover SWeet.
Old Jan 16, 2011 | 02:05 PM
nismomaxgtr18's Avatar
4th gens should have came from factory with DEKs! lol
Old Jan 16, 2011 | 03:19 PM
NAS's Avatar
NAS
Absolutely frecken yah!
Old Jan 16, 2011 | 04:01 PM
tsheffler's Avatar
im going to get a motor tomorrow morning. 375$ w/ 19k, its been sitting ona shelf for 10 9 years because one of the top trans mounting holes are broke. the ear is broken off, but as of right now im fine with that. ill see when i get there. if it one of the top two im not worried about it. its been tested for leaks/ compression etc and has a 90 day warrenty so ima do that!
Old Jan 17, 2011 | 10:02 AM
defiance's Avatar
Im geussing thats a DE if its sitting for 10 years...
Old Jan 17, 2011 | 03:44 PM
tsheffler's Avatar
well i went today for the motor, the one that had 19 was alot more damaged than specified, since it sat so long and was so high and out of reach, nobody *really* took a good look at it. the oil pan was destroyed, the trans mount ear was crack and the crack made its way into the block. long story short i didnt get that one, luckly they had another one but it had 106k on it so i got it anyways. i came all that way i wasnt going to leave without a motor lol. and it was a dek.
Old Jan 17, 2011 | 05:38 PM
ampire's Avatar
The motors will run forever anyway. You could try getting a VAFC2 and using the vtec controller to flip your DEK intake manifold, bonus is tune it with the VAFC2. I got my VAFC2 for $150 so its a affordable solution.
I'd consider a new water pump if you are doing the chains. Also, you may want to swap your DEK Intake cams to DE intake cams as I said in a PM. It may not be worth the effort of taking the cam bolts and journals off.
Old Jan 17, 2011 | 10:20 PM
defiance's Avatar
Just curious but what will the DE intake cams do for the DEK ?
Old Jan 18, 2011 | 05:51 AM
ampire's Avatar
slightly more aggressive intake cam duration. If doing all the work to change them it would be even better to just use 3.5 cams I think.
Old Jan 18, 2011 | 07:14 AM
essential1's Avatar
ding ding ding! We have a winner. Stock 3.0 cams are pretty conservative weather it be de or dek cams.
To the OP, I have a spare set of 3.5 cams for sale if you wanna go ahead and toss those in.
Old Jan 18, 2011 | 07:39 AM
ampire's Avatar
Do this.
Old Jan 18, 2011 | 12:51 PM
tsheffler's Avatar
lol ive thought about it, but really dont wanna tear down a motor for cams, ive read some threads on it,and im not seeing the gains vrs work. is there a way to take the cams out w/out taking the timing covers off?
it wont be going in for another week or so *at most* because i have to get a buddy of mine weld the lower rad support to fix it, i also need to do some searching cuz they'res a few tubes/ and nipples that are unused or open ended, and i need to find out where they go etc. and i need to figurre out how i want to do the fuel system.
Old Jan 18, 2011 | 02:43 PM
essential1's Avatar
You have to take the covers off to get to the cams. I know its frustrating when you do a valve cover gasket change and you think to yourself, "The cams are RIGHT THERE!" But once the motor is out the car, its seriously not that hard.
Most of the vacum ports can just be blocked off on a dek when swaping it into a 4th gen. Its alot more simple than it seems. And as far as the fuel goes, as long as you got the complete fuel rail and injectors with both fuel dampeners, its simple.
Old Jan 19, 2011 | 01:21 PM
tsheffler's Avatar
Ok so today I deleted the swirl valves completely...will Jb weld the holes when I stop at a store n get it. Now...my next question is: can that box on the side of the intake be taken off and blocked off or can I just plug the T fitting which I believe goes across the intake to control the butterfly valves... any input will help with this swap thanks!
Old Jan 19, 2011 | 01:27 PM
essential1's Avatar
The plastic fitting farthest to the right on the VIAS assembly is supposed to be blocked off when you remove the swirl/butterfly valves from the lower intake manifold. The 2 metal vacum fittings facing forward on the VIAS are left open.
