Im having some electricla problems that are stealling my horsepower
Old Jan 18, 2011 | 04:49 PM
K31J1m0N's Avatar
Well i sourced the problem out and i just need help finding all the important grounds under the hood since im gonna replace my engine harness with a full manual one since my harness once belonged to an automatic...can someone tell me or take pics of where all the important grounds should go and where i should add extra grounds to please...thanks fam
Old Jan 18, 2011 | 08:28 PM
shadyonedeath's Avatar
No, but you can help yourself to the Search button.
Old Jan 19, 2011 | 06:40 AM
njmaxseltd's Avatar
Electircal problems?
Auto to manual harness?
Grounds?
None of these will cause a loss of power per say.
What is your car actually doing or is your butt dyno out of calibration?
Old Jan 19, 2011 | 04:01 PM
K31J1m0N's Avatar
dude take that somewhere else...i wouldnt ask a question if i could find it
Old Jan 19, 2011 | 04:03 PM
K31J1m0N's Avatar
Grounds?
its a manual with a auto harness rewired for manual...it doesnt jerk or anything, it just doesnt pull above 3000rpm...takes forever and a day to pic up speed...someone said my safc or ecu could be looking for my egr since its not plugged in and is causing it to lag but imma put my 99 5speed harness in and see if that helps...im not going to enjoy this to the least
Old Jan 19, 2011 | 04:49 PM
Maximar's Avatar
You sure your intake and exhaust arn't just stuffed up?
Old Jan 19, 2011 | 05:10 PM
K31J1m0N's Avatar
i msure..just did an engine swap so i checked everything before i put the engine back in ....everything is clean
Old Jan 19, 2011 | 05:22 PM
Maximar's Avatar
Tuning and timing re adjusted for the new engine?
Old Jan 19, 2011 | 05:25 PM
K31J1m0N's Avatar
its the same 3.0 and i retuned it..i dont man this ish is getting annoying
Old Jan 19, 2011 | 05:53 PM
Maximar's Avatar
Well, engines are a *****, i've spent the past year trying to get the fuel system on my Javelin workin right only to find that there was a 2 foot long rag in the fuel tank, then the day we fix that the Alternator died. I was workin on an "86 560SL and couldn't get it running strong. One day i Just took the engine apart and put it back together and it felt as if the engine was brand new. So as much as a ***** as it might be you might want to try that.
Old Jan 20, 2011 | 05:45 AM
K31J1m0N's Avatar
[quote=Maximar;7897572]Well, engines are a *****, i've spent the past year trying to get the fuel system on my Javelin workin right only to find that there was a 2 foot long rag in the fuel tank, then the day we fix that the Alternator died. I was workin on an "86 560SL and couldn't get it running strong. One day i Just took the engine apart and put it back together and it felt as if the engine was brand new. So as much as a ***** as it might be you might want to try that.[/quotewut the hell was a two foot rag doing in ya tank....wut girl u **** off
Old Jan 20, 2011 | 06:20 AM
cashoit's Avatar
there are grounds on the intake manifold, near the passenger headlight, the tranny ground, and the battery ground on the engine. There are a bunch under the dash. THats all i know
Old Jan 20, 2011 | 02:54 PM
Spyguy's Avatar
All big metal parts are grounds.
Old Jan 20, 2011 | 07:47 PM
Maximar's Avatar
It was probably in there when we bought it a few years back. Seeing as my gas cap has a lock on it and it's hidden behind the liscense plate, so most girls can't get to it. But, going back to my previous suggestion, you probably don't need to take the whole engine apart but, since you think it's an electrical issuse, i'd go over the engine's wiring first to make sure it's not something like a weak spark plug.
Old Jan 20, 2011 | 07:53 PM
K31J1m0N's Avatar
i didnt say iwas gonna take the engine apart..i swapped harnesses 3 times times in 2 days and gonna run through the wires agaikn in the morning...fixed most of the things though
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
