Possible damaged strut?
Old Jan 19, 2011 | 05:40 AM
NABU6's Avatar
I recently had my struts replaced, and I have noticed that the lock nut on one of the struts, doesn't appear to be tightening correctly. The nut and the shaft of the strut appear to be spinning together. Is this a bad strut, or is the strut mount defective?
Old Jan 19, 2011 | 06:15 AM
nelledge's Avatar
"I'm just sayin'..."
Sounds like the strut mount needs to be replaced. There's a notch (for lack of a better vocabulary) in the shaft and in the mount which should hold the shaft from spinning when you tighten the nut. Either that notch has worn away or your strut was not installed properly.
Old Jan 19, 2011 | 06:18 AM
NABU6's Avatar
Thanks for the response. I have a feeling that it wasn't installed correctly since the strut mount itself was a brand new, OEM part. Unless the part itself was damaged.
Old Jan 19, 2011 | 06:29 AM
njmaxseltd's Avatar
Go bad to the shop that put the struts in and show them what's happening.
Old Jan 19, 2011 | 07:17 AM
NABU6's Avatar
Oh, I'm definitely going to do that. Just wanted to get a get a feel as to what it might be before going back. Always good to have information on your side.
Pnjboyzz
Nov 16, 2015 12:27 PM
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
