Announcement: The Mopar Oil Filter Study link has been updated....
Old Dec 20, 2001 | 06:44 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
in the Maintenance Sticky Thread. I found a more reliable source.
Happy Reading!
Old Dec 20, 2001 | 06:49 AM
Sprint's Avatar
i didn't read it before
Old Dec 20, 2001 | 09:16 AM
bill99gxe's Avatar
Sprint,
That would make you a member of the majority.
Maybe you should read it so you can go back in the minority?
Old Dec 20, 2001 | 09:19 AM
Sprint's Avatar
Originally posted by bill99gxe
Sprint,
I am going to print it out and take it to the toilet the next time i go so i can read it in peace
Old Dec 20, 2001 | 09:24 AM
Sprint's Avatar
http://www.frankhunt.com/FRANK/corve...ilfilters.html
Filters To Avoid
The following list of filters have known problems. You will see well-known names here and will probably be disappointed. This is because many of these brands have stopped making their own filters and buy from a common manufacturer.
Fram Extra Guard
Years ago Fram was a quality filter manufacturer. Now their standard filter (the radioactive-orange cans) is one of the worst out there. It features cardboard end caps for the filter element that are glued in place. The rubber anti-drainback valve seals against the cardboard and frequently leaks, causing dirty oil to drain back into the pan. The bypass valves are plastic and are sometimes not molded correctly, which allows them to leak all the time. The stamped-metal threaded end is weakly constructed and it has smaller and fewer oil inlet holes, which may restrict flow. I had one of these filters fail in my previous car. The filter element collapsed and bits of filter and glue were circuilating through my system. The oil passge to the head became blocked and the head got so hot from oil starvation that it actually melted the vacuum lines connected to it as well as the wires near it.
Fram Double Guard
Another bad filter idea brought to you by your friends at Fram. The filter itself is a slightly improved design over the Fram Extra Guard, but still uses the same filter element. It has a silicone anti-drainback valve, a quality pressure releif valve, and enough inlet holes for good flow. The big problem is that they are trying to cash in on the Slick 50 craze. They impregnate the filter element with bits of Teflon like that found in Slick 50. As with Slick 50, Teflon is a solid and does not belong in an engine. It cannot get into the parts of the engine that oil can and therefore does nothing. Also, as the filter gets dirty, it ends up filtering the Teflon right out. Dupont (the manufacturer of Teflon) does not recommend Teflon for use in internal combustion engines. Please do not waste your money on this filter.
Penzoil
This filter is a Fram! It is the exact same design as the Fram Extra Guard filter and it is junk. On the up side, it costs $1 less than the Fram version.
Quaker State
This is another Fram Extra Guard that I have seen at K-mart. It used to be a Purolator, but Quaker State is now owned/controlled by Penzoil...
HOW MANY TIMES DO I TELL PEOPLE.. STOP WATCHING COMMERCIALS.. STAY AWAY FROM FRAM...
but they choose to ignore me and they never listen
Old Dec 20, 2001 | 10:39 AM
njmaxseltd's Avatar
Does anybody know who actually manufactures the Nissan Oil Filter?
That was good reading material on that web site Sprint. Now my bathroom stinks...
Old Dec 20, 2001 | 10:48 AM
Sprint's Avatar
I agree
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
JoshG
51
Sep 21, 2015 10:41 PM
cruce91
Sep 20, 2015 10:23 AM
97_GXE
20
Sep 17, 2015 08:12 PM
sdotcarter
Sep 2, 2015 09:53 PM
