Stock Ground Locations?
Old Jan 30, 2011 | 04:38 PM
TheWhiteWhale's Avatar
Hit 198k today and decided it was about time to clean them up-found 2 over by the horn and one by the battery. Cleaned up the knock sensor grounds as well, but I couldn't find any of the others. Checked the FSM, stickies, and searched but couldn't the stock locations listed. Anyone found them all?
Oh and just from cleaning those there was a noticeable difference in transmission shift times (auto), and the lights seemed a bit brighter (but that could be a placebo effect)
Old Feb 1, 2011 | 09:01 AM
Dillano609's Avatar
Not sure if I'm just repeating some of the grounds you cleaned, but I'll try anyway. There is a ground behind the right headlight, by the windshield washer resevoir opening. Then there is another below the bottom of the airbox/air intake. Then there are a few on the alternator (A slight pain to do). Then the last ones I know is the Knock sensor grounds you already took care of on the Intake Manifold.
Hope this helps
Old Feb 1, 2011 | 12:17 PM
DBear's Avatar
There's also one by the left headlight, not quite in the same position as the one by the right headlight. I just found these two this weekend.
pktaske
May 6, 2016 07:49 AM
BkGreen97
Apr 2, 2016 05:47 AM
pktaske
Sep 4, 2015 08:40 AM
