Brake Light Switch
Old Feb 9, 2011 | 07:57 AM
Justaguy's Avatar
Brake Light Switch
I think the stickies should include this topic...
I've checked the FSM and can't seem to locate it (nothing under brake light switch)...lots of posts but no mention on how/where to replace it.
Anyone point me in the right direction?? Thanks
(My back brake lights -all three of them don't light up when the brake is pressed). I know I have to replace this Brake light switch as mentioned in so many posts, just don't know what it looks like and where it's at.
I was looking in the el.pdf document of the fsm.
Old Feb 9, 2011 | 08:28 AM
bobflood's Avatar
The switch is on the brake pedal bracket; same switch turns on your brake lights and shuts off your cruise control. In the 97 FSM, it's on page BR-6. Hope this helps.
Old Feb 9, 2011 | 11:20 AM
njmaxseltd's Avatar
You did check the fuse first, right?
Old Feb 9, 2011 | 12:29 PM
maxed_out_99's Avatar
maybe all your bulbs are burned out
just kidding
as stated above the brake light switch is on the reverse side of the brake pedal
there should be 2 wires going to it
Old Feb 9, 2011 | 12:50 PM
Justaguy's Avatar
Ahhhh Thank you! Found it exactly where you said it was...I was looking in the wrong document.
yes I did check the fuses and they are all good..including under the hood.
Thanks!!!
Old Feb 20, 2012 | 08:37 AM
StlChillin's Avatar
Can anyone provide guidance on how to remove the old brake light switch? It looks like its held in place by a bolt and the space is too tight for me to get tools in there to loosen it. I REALLY don't want to have to pay someone else to do such a small job. Thanks!
Old Feb 20, 2012 | 08:41 AM
StlChillin's Avatar
Sorry, I just realized this thread is from February 2011, not February 2012. Hope I don't offend anyone by ressurecting an old thread, but I still need help either way with this brake light issue... Thanks
Old Feb 20, 2012 | 06:46 PM
komik's Avatar
I recently had to replace the plastic button and adjust the switch position. IIRC, the switch itself screws into the bracket with an additional retaining nut that locks it into position. You should be able to squeeze a wrench in there to loosen the nut, then unscrew the switch assembly.
Old Feb 21, 2012 | 06:52 AM
bobflood's Avatar
+1 on this. Unplug the connector first so the switch will unscrew freely.
Old Feb 21, 2012 | 05:24 PM
Justaguy's Avatar
I had my friend who is a mechanic do it for me....It took him less than 1 minute but I couldn't see how he did it...sorry.
Old Feb 22, 2012 | 03:54 PM
StlChillin's Avatar
After some finagling, I managed to get the old switch out. Thanks guys!
tsi6001
Oct 3, 2022 10:23 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
