clutch question
Old Feb 9, 2011 | 12:41 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
clutch question
sow hen i did my 5 speed swap the clutch has slipped since day one under hard acceleration. its a stage one exedy brand new. now im doing a motor swap and am wondering if i should put a new clutch in. ideas ? could it have been a bad unit or is there something i missed during the swap years ago that would have caused the clutch to slip ?
Old Feb 9, 2011 | 12:43 PM
phatboislim's Avatar
first i've ever heard of an exedy clutch doing that..they normally have great reviews...i personally have a competition clutch stage 1 in mine...absolutely no problems...a little more chatter than i did when i had one in my GSR, but its no biggie, and not that evident
Old Feb 9, 2011 | 12:57 PM
ken85's Avatar
Is your car stock or only have minor mods? Why not use a stock clutch? But anywho, I never had any issues out of my exedy stage 2 in my turbocharged civic.
Old Feb 9, 2011 | 01:32 PM
YoU CaNt SeE mE
minor mods nothing crazy i guess i could just get any old clutch from the parts store...just hate stock stuff lol...
Old Feb 9, 2011 | 03:34 PM
aackshun's Avatar
Wait wtf? Did you wail on your car right out of the driveway?
You realise the clutch system is one big brake, just like bedding in brakes you have to break in the clutch.....
And if you're doing a VQ35 swap you'd need atleast a stage II clutch from exedy, stage I is pushing it (a stage I Z32 N/A clutch disc is barely suitable though, if you're on a budget just go with that then).
Old Feb 10, 2011 | 11:20 AM
YoU CaNt SeE mE
Probably a bad unit and no it's a vq30 with minor mods nothing crazy
Old Feb 10, 2011 | 01:18 PM
cashoit's Avatar
how is the flywheel? there is usually a break-in period for the clutch.
Old Feb 10, 2011 | 02:21 PM
asand1's Avatar
Did you clean the surfaces of the flywheel and PP?
Old Feb 10, 2011 | 07:23 PM
315max's Avatar
did you go through the break-in period? did you adjust the clutch so when you release the pedal it fully engages the pressure plate?
Old Feb 11, 2011 | 07:30 AM
adroitcaptor's Avatar
I doubt that it was a bad unit for reasons already stated.
Based on your post it is much more likely your fault. At that, again an assumption, probably improper break-in. This is the most common issue with slip, bounce, and chatter.
To answer your OP, yes, you should put in a new clutch. You should also take asand1's advice if you do it yourself and aackshun's advice with the stronger clutch.
Old Feb 11, 2011 | 01:01 PM
YoU CaNt SeE mE
im going to replace it but im just throwing in a new stock clutch moneys tight im already changing the motor. The flywheel was a brand new fidanza at the time with a brand new exedy. i cleaded it with brake fluid like instructed and installed it. we have hydraulic clutches there is no adjustment what you see is what you get.
Old Feb 12, 2011 | 01:49 AM
Problem found, you "cleaned" it with break fluid.
Yes, there are adjustments.
Old Feb 12, 2011 | 01:50 AM
aackshun's Avatar
We'll give him a chance, maybe he meant brake cleaner... Then by all means he's in the clear.
Oh lord, adjusting our clutches..... P.I.T.F.A, well for me anyways, I'm a big guy, I was not meant to be adjusting Maxima Clutches.
Only adjust your clutch as a last resort after all other things have been tackled, eg. if you have low engagement, try re-bleeding it, rebuilding the slave cylinder, etc, the very last two things I would do is Replace the master cylinder (which I need to do) and adjust the clutch to fix an engagment problem.
Old Feb 12, 2011 | 04:41 AM
YoU CaNt SeE mE
not brake fluid !! lmfao brake cleaner. i am however interested in how we adjust these things. cause i did have a low engagment but i bled the crap out of the lines there was no air in there yet still low engagment present. i could physically lift the petal to the top and then it would almost operate at a normal engagment for a short while.....maybe master...hummmm
Old Feb 12, 2011 | 03:09 PM
315max's Avatar
just because its a hydrauylic clutch doesnt mean there is no adjustment. its actually quite challenging doing a clutch job yourself. check the lines a cylinders for leaks. i honestly forgot how i did it when i replaced the clutch in my 97 max se. i had to push the clutch in at the same time i was tightening the bolts and checking fluid level. just double check everything before you put a stock clutch back in
Old Feb 12, 2011 | 03:42 PM
asand1's Avatar
If I'm not mistaken the only adjustment is actually pedal height. With the Master cylinder at rest, the reservoir port is opened, and line pressure is vented into the reservoir. However if the pedal was adjusted too high, it might keep enough pressure on the MC that the reservoir port system remains closed.
Inversely, If the pedal is too low the clutch will never fully dis-engage. It will drag and be hard to shift. This will cause premature wear and eventually slip.
Old Feb 15, 2011 | 07:30 PM
YoU CaNt SeE mE
It's all good I completed the motor swap with a new clutch and she is back on the road. I'm babying it best I can right now
Old Feb 16, 2011 | 08:21 AM
cashoit's Avatar
Yes. U can adujust clutch pedal engagement height.
the master cylinder has a plunger that is attached to the clutch pedal. That plunger has a nut on it that adjusts the height of the clutch pedal. look on the back of the clutch pedal, locate the plunger, adjust the nut until the engagement point suits u. U will have to test drive the car until u get the right comfortabnle setting.
SEARCH the org. I started a thread where i had a problem with engagement point and how to adjust.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 20, 2015 11:46 PM
pears
Sep 18, 2015 05:25 AM
Johnny9595
Sep 3, 2015 05:18 AM
