It's Back On The Road! But not quite right.
Old Feb 13, 2011 | 09:23 AM
txsilverado1's Avatar
Well the $750 1999 Max GLE with 115k miles I bought that was wrecked is back on the road. It took more than I expected. Mostly because I tried to go with used parts and they ended up being worn out. So, I ended up buying new stuff anyway. So here's the run down on parts replaced so far.
Front wheels/tires
rear motor mount
front crank seal
A/C compressor
compressor mount bracket & bolts
oil pan and pickup tube/screen
camshaft position sensor o-ring
lower control arms with b. joints and bushings
K-frame AKA cross member
longitudinal engine support brace "holds front and rear motor mount"
sway bar and end links
rack & pinion with tie rod ends
front brake pads
left drive axle
right wheel well splash shield
Exhaust manifold gaskets
I drove it to work today. It is still a little off. I ordered a full set of pre-assembled front and rear struts today along with a new set of NGK irridium spark plugs.
I hope that ends up being all. I am at about $2k into the car including buying it now. It adds up fast! It ended up costing me over $200 for a lifetime warranty alignment and 2 old wheel lock removals at Firestone alone.
I am kinda partial to these cars. I put 200k on two in the past. There's just not too many cars out there for the money that compare to the 95-99 Max and I30.
Old Feb 13, 2011 | 10:17 AM
Trini Boom's Avatar
Front wheels/tires
rear motor mount
front crank seal
A/C compressor
front brake pads
left drive axle
The car will look after you and thank you later so don't worry about the amount of money being put in. Lifetime wheel alignment does sound very interesting though...only Firestone has this feature??
Old Feb 13, 2011 | 10:22 AM
Firestone is the only one I am aware of that offers the lifetime alignment. I know it's expensive at first, but make sure you use it a couple of times and it pays for itself. I think they do it so they can get repeat business to repair worn front ends and tires/brakes and such. I find it handy because it is honored at all Firestones nationwide.
JRod28
Dec 29, 2023 09:56 PM
tsi6001
Oct 3, 2022 10:23 PM
mvm062
Nov 30, 2020 09:00 AM
Justin Kroll
Sep 2, 2015 11:06 AM
Lowered_a33
Aug 24, 2015 04:35 AM
