Cold Start Problem Solved~~
Old Dec 21, 2001 | 09:11 AM
taeMAX97's Avatar
okay guys.. those of you who posted about their car not startin when it's colder outside BE HAPPY. cause the problems solved. just clean YOUR THROTTLE BODY~!~!~!~!~!~! no questions need to be asked. JUST DO IT. it only cost me $5. i picked up STS(???) THROTTLE BODY AIR INTAKE cleaner and a heavy duty papertowel from autozone. and it only took me 30 mins at the most. and BOOM it's workin fine. i don't know about performance and ride comfort as other ppl said. but it sure solved that cold start problem. so if you need instructions on how to check it out at www.motorvate.ca GOOD LUCK
tae
Old Dec 21, 2001 | 09:16 AM
Sprint's Avatar
i think i need to clean mine properly again.. i did it before.. my idle problem went away.. and now its slowly coming back.. i thikn i will try the old toothbrush thing
Old Dec 21, 2001 | 09:21 AM
taeMAX97's Avatar
yeah i forgot to mention that i used toothbrush too.. hehe
oh and when was the last time you cleaned it?
Old Dec 21, 2001 | 09:32 AM
Sprint's Avatar
last month.. but i used a towel.. and i couldn't get in there good enough.. so i think that maybe have been a temporary fix
Old Dec 21, 2001 | 10:10 AM
taeMAX97's Avatar
last month?????? wtf~!~!~!~!~ @.@
wow so you probably didn't even get to the dirty part then eh~?
well toothbrush worked well. and i used half of that cleaner. mine wasn't dirty when you look at it. but once you spray that cleaner on~~~~ it's like chocolate milk...... YUK~~~~~~~~
Old Dec 21, 2001 | 10:11 AM
Jr'sMaxima's Avatar
Looks like my dad has a project this week for his week off!! LOL
Old Dec 21, 2001 | 11:48 AM
taeMAX97's Avatar
do it JR. do it do it do it.
JUST DO IT
Old Dec 21, 2001 | 12:25 PM
Mishmosh's Avatar
If you REALLY want to ensure that you do a thorough job, unbolt the throttle body completely. Leave the hoses on there, but when you take the four bolts off, it will give you plenty of room to tilt the inner side toward you. You can also rest assured that you are not scrubbing anything into the intake.
This is the 2nd report of cold starting problems going away with the TB clean. That is AWESOME if it holds up. Kind of makes sense... at least time wise for me. My 95 started up flawlessly every winter except last year which was it's 5th year with about 55k miles on her. It probably was time for a TB clean...
Old Dec 21, 2001 | 02:43 PM
Jr'sMaxima's Avatar
Naw, I gotta work during the days and he's off plus he can fix just about anything on cars, and he will need something to do other then sleep all damn day....LOL. Hes gonna fix my sticking starter too!
Old Feb 9, 2002 | 11:28 AM
MaxiPad96's Avatar
I cant pull the starter out.. is it the smaller of the two bronze cylinder or is it the larger one.. I removed the connectin to the battery and the other bolt connecting to the largr broze cylinder.. I cant pull the thing out though.. ANYONE?
Old Feb 9, 2002 | 12:05 PM
Mishmosh's Avatar
the starter consists of the starter motor and the solenoid. They are part of the same unit and come out en block. There are two bolts that must be loosed, the furthest back of the two is longer and harder to loosen.
Old Feb 9, 2002 | 12:18 PM
KWheelzSB's Avatar
Start by loosening the two bolts going into the bell-housing.
Lakersallday24
Nov 7, 2024 07:31 PM
tsi6001
Oct 3, 2022 10:23 PM
cruce91
Sep 20, 2015 10:23 AM
FlaMark
Aug 21, 2015 11:06 AM
kirkhilles
Aug 8, 2015 10:53 AM
