water in rear light - pic
Old Mar 14, 2011 | 01:57 PM
kel456's Avatar
every time after a rain i get water dripping into the trunk, of course, when opened. it usually roughly about 1 oz of water. anyone has the same experience?
Old Mar 14, 2011 | 02:33 PM
luke95gxe's Avatar
yes i did also had to take the tail light out and reseal it u need a 8 mm deep well socket remove and reseal u might wanna take a look at where ur spare tire sits although it may look like a lil bit of water my spare tire area was completly under water
Old Mar 14, 2011 | 02:36 PM
Dougy Trah's Avatar
Yes I have the EXACT same problem. However, mine is because I have a crack in my tail light :P
Old Mar 14, 2011 | 06:35 PM
kel456's Avatar
I have never dealt with lights before. I appreciate with some details. Is it straightforward removal?
What kind of sealant is recommended? butyl rubber? a gasket if any?
Thanks.
Old Mar 14, 2011 | 06:54 PM
luke95gxe's Avatar
Thanks.
disconnect the wire from the bulb assembly then remove the four 8 mm nuts then u will prolly have to pry up on the lens it in there tight no gasket i used silicon what already there is some black sticky stuff like they use for windshields u could find something at a parts store that will suffice i just caked it on then torqued it back down really straight foward
Old Mar 14, 2011 | 07:52 PM
nitromax's Avatar
after getting all of the nuts off, a heat gun will help with getting the sealant around the light housing to release, just not too hot & not too long..lightly press out while heating.
carguy96
20
Feb 6, 2021 06:21 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
Huttig2009
Sep 25, 2015 03:31 PM
