AC comprassor not starting
Old Mar 19, 2011 | 08:07 AM
maxam's Avatar
hi guys
summer is comming . the wethar becomes hot . so I started the AC and I surprised with hot air . I notes that the comprassor did not start becouse I did not hear it's sound .
any thing to fix this problem ?
Old Mar 19, 2011 | 08:53 AM
DennisMik's Avatar
If the refigerant (freon) leaked out, the compressor will not run as there is a pressure sensor.
Old Mar 19, 2011 | 11:23 AM
maxam's Avatar
ahaaaaaa . I see now .I will fill in and try . thanx alot
Old Mar 20, 2011 | 12:57 PM
HomerMAC's Avatar
Donating i30 Owner
make sure you drain and fill it with the coolant and the lubricating OIL from nissan.
ALSO there is a trigger switch on the compressor (black connector with black single wire). Ensure that is still there and in tact.
Old Mar 20, 2011 | 03:10 PM
T-Mon3y's Avatar
Probably a leak, Dead Compressor, or compressor clutch is not engaging(could be many other things too). But be careful refilling R-134a from the "can" can be dangerous/explosive, also there is really no way to meter how much refrigerant is in your a/c system already or how much you're putting in.
Honestly I would get a/c work done professionally. But if you insist on doing it yourself wear eye protection because getting that stuff in your eye will most likely freeze it and when u blink it will shatter.
Oh and DO NOT USE THAT STOP LEAK **** OR ANYTHING THAT CLAIMS TO STOP LEAKS, it will plug the leak and any other orifice in your a/c system.
Old Mar 21, 2011 | 06:45 AM
JwaxMax99's Avatar
No don't just "fill it". You need to put dye in the system and find the leak..... Take it to to a shop.
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
