confused with codes
Old Mar 31, 2011 | 01:13 PM
2THEMAX98's Avatar
confused with codes
my check engine light came on, so i pulled the codes. 03,04 which on here says its a knock sensor. and a code 05,03 which says is a front right heated sensor. i pulled them from here http://vbxmaxima.8m.com/ecudecoder.html
now i called places around me and they're all telling me different things so i'm confused as to what they mean. autozone said i don't have a front heated sensor and that it was a cylinder 4 misfire? and napa told me different as well. can someone explain what it is or how i can fix it. thank you
Old Mar 31, 2011 | 01:18 PM
maxfever1987's Avatar
po304 is a cylinder 4 misfire, you might need, an injector or coil, go with the ignition coil first
Old Mar 31, 2011 | 01:19 PM
2000_MAXIMA_KING's Avatar
Ok there is the nissan codes that you pull with the flashing lights for instance 0304 which it looks like you did autozone is talking about the P0304 which is a universal code that is read by a obd2 reader. If you want to confirm the codes you looked up go to autozone and have them pull the codes and they should correspond to the same thing. Also in one of the stickies there is a post that cross references the nissan codes with the reader codes, you can look it up to confirm.
Old Mar 31, 2011 | 01:20 PM
Maxfever he didn't say it was the p0304 code.
Old Mar 31, 2011 | 01:27 PM
2THEMAX98's Avatar
the codes i got are from the blinking light in my car 3 long pulses and 4 short pulses, same with 05,03
Old Mar 31, 2011 | 02:12 PM
RA030726's Avatar
I'm nutty for Nissans
Replace the O2 sensor and the KS code will go away.
Old Mar 31, 2011 | 02:17 PM
What jsutter just said is the way I would go.
Old Mar 31, 2011 | 02:20 PM
2THEMAX98's Avatar
alright, i'll do that. do you think this has anything to do with me needing to change my spark plugs? and is 120$ about right cause that is what autozone quoted me
Old Mar 31, 2011 | 02:22 PM
2THEMAX98's Avatar
just found this byu typing 02 sensor on ebay, this will work?
http://cgi.ebay.com/ebaymotors/MAXIM...Q5fAccessories
Old Mar 31, 2011 | 02:32 PM
asand1's Avatar
Denso direct fit from ROCKAUTO.COM. ~$50 shipped. DO NOT replace KS yet, replace O2 sensor first. KS is probably a ghost code created in conjunction with the O2 code, very common with the 4th gen.
Old Mar 31, 2011 | 03:06 PM
2THEMAX98's Avatar
so there is a difference between knock sensor and 02 sensor? cause i type 02 sensor on ebay and it shows both?
Old Mar 31, 2011 | 03:12 PM
Shift_Nismo's Avatar
This is a knock sensor:
This is an 02 sensor:
Old Mar 31, 2011 | 03:36 PM
2THEMAX98's Avatar
alright, thank everyone for your help, i will be looking on rockauto as soon as i get home from work
Old Apr 1, 2011 | 11:29 AM
T-BlackMax's Avatar
knock sensor pretty much puts your car into limp mode
Old Apr 1, 2011 | 08:12 PM
asand1's Avatar
I would say that's not accurate. You lose a little power and fuel economy. Limp home mode is under 3K RPM and stuck in second gear for the AT guys. For the most part, a bad KS is unnoticeable.
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
