Help identify this sound...
Old Apr 1, 2011 | 10:44 PM
sunshine7684's Avatar
It sounds sorta like a knife being sharpened, almost. I think it's coming from the front end, but i'm not really sure. You can only hear it when the windows are down and i'm pretty sure it's not like an engine thing because i can still hear it when it's rolling in neutral--but it's relative to the car's speed, as in if i am rolling faster the sound is made faster. It's just like a metal on metal noise. As far as i know it's not doing anything terrible.....
Old Apr 2, 2011 | 12:03 AM
T-MAX's Avatar
Sounds like your discribing the sound of your brake wear sensors probably time for some new brake pads.
Old Apr 2, 2011 | 09:06 AM
DennisMik's Avatar
It could be a CV joint or a wheel bearing. Check the CV joint rubber boots (all 4) to see if any are torn/ripped. If so, there's your problem.
Old Apr 2, 2011 | 10:05 AM
GGENIUS's Avatar
rotors
Old Apr 2, 2011 | 12:53 PM
@tmax and ggenius....I just got my whole brakes redone like 6 months ago...
Old Apr 2, 2011 | 07:20 PM
ctsnyper's Avatar
Not a lot of info to go on, but it could be the brake caliper starting to seize.
Old Apr 2, 2011 | 07:57 PM
luke95gxe's Avatar
could be dust sheilds rubbin
Old Apr 2, 2011 | 07:58 PM
how you move those?
Old Apr 2, 2011 | 08:02 PM
luke95gxe's Avatar
Originally Posted by sunshine7684
how you move those?
they are attched to the back of the rotor some times they get bent an rub the rotor causing a scraping noise u can bend them back out with a flat head screw diriver with out removing the wheels
Old Apr 2, 2011 | 08:08 PM
luke95gxe's Avatar
but more than likely it is wheel hub i chased a noise like what u describe for a while an turned out was the hub bearings
D Mason
Jun 21, 2016 04:43 AM
follyburr
Detailing
Jun 13, 2016 02:06 PM
followthadollar
Sep 13, 2015 09:55 AM
0m3nc0w
Sep 11, 2015 05:21 PM
Colossus
Sep 9, 2015 05:46 AM
