VAFCII install question!!!
Old Apr 14, 2011 | 09:02 AM
drkblumaxima's Avatar
I am planning on hooking up a VAFC2 on my 96 maxima and have 2 questions if anyone knows. On the vafc2 there is a LIGHT BLUE wire and a BLUE wire which one is for the O2 sensor? I also have a RED wire and a RED/BLACK wire the diagram show that you splics 2 RED wires 1cm. So my question is since those are the only two wires that even have the color red on it is the one that is RED/BLACK the right one to splice in with the solid RED wire? I have all the diagrams/instructions on hooking it up but nothing states which blue wire is actually for the O2 sensor or if the red/black wire is the right one to connect with the solid red wire.
IF ANYONE HAS INSTALLED ONE OR KNOWS ANY INFO PLEASE LMK SO I DONT FCK ANYTHING UP!! Thanks
Old Apr 14, 2011 | 09:48 AM
Here you go
http://www.vqpower.com/v2/articles.php?article_id=98
Old Apr 14, 2011 | 10:45 AM
Thanks but i already got that site... still doesnt say which blue wire on the VAFC is for the O2 sensor.Blue or Light Blue?... Doesnt show pics of the actual wires off the VAFC..just a diagram
Old Apr 14, 2011 | 11:00 AM
I thought it was pretty clear.........
" Please note that you will not be using the Light Blue
, Purple, or Orange wires from the V-AFC harness, tuck them away"
Old Apr 14, 2011 | 12:36 PM
Ok you got me on that one...lol i did read that part but just being paranoid about my blues..... Glacias por favor for the wake up call
Old Apr 14, 2011 | 12:52 PM
shadyonedeath's Avatar
vafc2 install inside. g'luck
http://forums.maxima.org/all-motor/5...1999-se-l.html
Old Apr 14, 2011 | 01:05 PM
Originally Posted by shadyonedeath
/\ Awesome link. Great job shady.
Also, in the following discussion (link below), it appears the O2 sensor wire may not even need to be wired in (per post #24)..
http://forums.maxima.org/all-motor/3...-complete.html
Old Apr 14, 2011 | 01:40 PM
I'll have to read my VAFC manual again because I totally forgot about that blue o2 wire. I remember leaving it alone because I didn't have a wideband at the time. Might be able to have real time AFR value on the VAFC monitor screen.
Edit: Nope. Blue wire not even necessary.
Old Apr 14, 2011 | 01:48 PM
NmexMAX's Avatar
dot dot dot ...
Never heard of that.
*Edit
I didn't think so, since most of use the packaged software with our WB's.
Old Apr 14, 2011 | 02:09 PM
While we're on the topic on VAFC installation,
I just finally finished doing the wiring to activate the MEVI on my daily driver 98 Max using my trusty () Harlan RPM switch.
If I wanted to ditch the Harlan and use the VAFC for future tuning and control the activation point of the MEVI, how would I go about it? Is it as simple as removing the Harlan, then taking the pink wire from the VAFC and tying it into the relay where the white wire of the Harlan used to go (85 on the relay)??
The diagram below is how I have my MEVI being activated on both on my Max's.
Old Apr 14, 2011 | 04:10 PM
Yes, pink wire for 12v activation signal.
Old Apr 16, 2011 | 02:10 PM
JNCoRacer's Avatar
Just the tip.
Does anyones VAFC feel hot to the touch after a while?
Old Apr 16, 2011 | 07:30 PM
FallenOne's Avatar
Its the Dot Matrix screen i think..
PH98I30
Jan 9, 2025 08:08 AM
JRod28
Dec 29, 2023 09:56 PM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
