Top Speed, 95 vs 99
Old Dec 23, 2001 | 02:51 PM
JUDE's Avatar
Top Speed, 95 vs 99
The 95 SE 5spd has been tested to 142mph, and the 97-99 Maximas 5spd were only tested to 130mph.
The same way that the 95s are faster then the 99s because of emissions control & weight, is this also the reason the top speed is slower? There is no speed limiter at all on SE's which means that with mods, the top speed should increase as well as accelaration. Right?
Old Dec 23, 2001 | 05:21 PM
justmax's Avatar
Re: Top Speed, 95 vs 99
according to whom? I have a '99 SE-L and have taken it to 140 (clear road, curious mind, etc...)
The top speed of the Maxima will occur in 5th gear just below the rev limiter, so the only way to increase top speed is to make your engine turn faster, make the body more aerodynamic, or maybe change the gearing in the tranny. There are no bolt-on mods that do any of those.
Make sense?
Old Dec 23, 2001 | 05:49 PM
dko's Avatar
dko
duck and cover
Re: Re: Top Speed, 95 vs 99
The JWT ECU will change your redline to either 6800 or 7000 even. this should provide a slightly faster top speed.
Old Dec 23, 2001 | 05:54 PM
kratz74's Avatar
I had 1 99 SE-L also and had it pegged on the speedo and wrapping around. After you hit 130 the car BARELY accelerates. I'm guessing the mags have only a short area to try top seppd. It took a mile-2 miles to get from 130 -140 (or at least it seemed that way). The car is a dog after 130... so if you race don't race past that speed
Old Dec 24, 2001 | 12:00 AM
puremax's Avatar
I had this same problem, after 135 mph, i went no where.
Old Dec 24, 2001 | 12:22 AM
papasmurf's Avatar
Honda Convert!
Ive gotten to 150 but i have done some extensive work to the under body areo dynamics and just to let you know bigger rims give higher top ends. when i tested it i was on 18's. The only reason i know it was 150 was i had a friend with a supra pace me. once i got to 135 it seemed to get to 150 farily quick. Just the other night going south on 95 a nother max (white 97-99 w/ all kind of strobs and slamed on cromes)decied to race and he found out about my top speed.
papasmurf
Old Dec 24, 2001 | 06:04 AM
HondaKiller718's Avatar
papasmurf
Are you sure the 18's did not affect your speedo? Did your friend get to the same 150 and did he/she have 18's?
Old Dec 24, 2001 | 06:14 AM
papasmurf's Avatar
Honda Convert!
yeah he has the same rims as me and yeah they affect your spedo but ours doesnt go that far so i went off of his and he said it only affects it by 1.5 mph so if you want to be technical 148.5.
Old Dec 24, 2001 | 11:51 AM
Amendemula's Avatar
do this
how about yall do this..
have a car that you know can do like 150
go infront of you.... and then you follow
that car... on its ***... and you'll have more
chances of getting to a higher speed...
this is dangerous, you know???
it worked for my friends accord.. it would take half the time if you follow someone cause you'd b like (i think the term is ) drifting
havent yall seen days of thunder????
Old Dec 24, 2001 | 12:02 PM
justmax's Avatar
Re: do this
Right on! Good idea: you'd be letting a more powerful car push most of the air out of your way and attain a higher top speed... but it's kinda cheating. You could also just let a Viper pull you to 170, and you'd be the fastest Max on the gound! Or put your Max inside the cargo bay of a 747 and be the fastest Max in the air. They're all cheating, but still, you'd have bragging rights.
Justin
Old Dec 24, 2001 | 12:07 PM
Amendemula's Avatar
Re: Re: do this
Justin
oh yeah good point....
well... if you want .. you could... just do that and when you think your car is at top speed pull out of the lil row.. and see if you decrease in mph?
Old Dec 24, 2001 | 12:29 PM
jules's Avatar
Re: do this
I think you mean drafting but yea...
Jules
Old Dec 24, 2001 | 12:38 PM
SuDZ's Avatar
Some of you get up to crazy speeds huh?
SuDZ
Old Dec 24, 2001 | 12:43 PM
justmax's Avatar
Re: Re: Re: do this
You would most certainly slow down.
Old Dec 24, 2001 | 12:47 PM
MaximaRider's Avatar
all i ask is that none of you kill yourselves.
Old Dec 24, 2001 | 12:54 PM
Amendemula's Avatar
i would never do it!! ****....
Old Dec 24, 2001 | 04:00 PM
max83's Avatar
drafting wont work the cars to heavy. true the faster car does get the air movin but you can't draft off another car
Old Dec 24, 2001 | 08:08 PM
Amendemula's Avatar
yoo.. its been done... in my friends accord... he could only top out at 120 and then one day we was followoing someone (behind them) (on there ***) and we went to 125
soo... i mean its just five miles more.. but its five miles!!
soo you cant say it cant b done..
im no rocket scientist das 4 damn sure
but... it can b done!
Old Dec 24, 2001 | 11:14 PM
jnmunsey's Avatar
Check these pics out
from an old thread I wrote - It shows 139 but my speedo actually made it to ~143..
http://forums.maxima.org/showthread.php?threadid=14651
Old Dec 25, 2001 | 02:23 AM
norton2099's Avatar
Re: Check these pics out
heh.. that's some self incriminating evidence right there , but i've taken my car past 140 too its damn scary...
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
Sep 27, 2015 08:37 AM
