Having a odd issue...
Old Apr 15, 2011 | 07:56 PM
killermax3's Avatar
Ok so to start car is throwing Knock sensor code and EGRC solenoid valve. I pulled these codes last week. I went out and bought the EGRC have not installed it yet, but a couple days ago noticed a very different sound coming from my exhaust. I have a custom cat back with a super street turbo muffler and a warpspeed Y. Both under 1 year on the car. The last few days the car has been sounding much louder and raspy. The deep tone is gone at low speed and only heard more at freeway speed. Could the EGRC be causing this or might I have a leak somewhere all a sudden? I have not hit anything that would cause a leak and the parts are still new. Thanks for help in advance.
Edward
Old Apr 17, 2011 | 09:00 PM
killermax3's Avatar
bump.. anyone please
Old Apr 17, 2011 | 10:05 PM
DennisMik's Avatar
The change in sound is very likely because of a leak. While the exhaust parts are fairly new and probably don't have any holes, a possibility is that something is coming loose. I read a thread here on the org several months back where the guy's y pipe came loose after almost a year. As far as the codes, I don't know if they are related to the change in sound or not. But the knock sensor code tends to accompany a lot of emission codes and goes away when you fix the other codes.
Old Apr 18, 2011 | 12:05 PM
cashoit's Avatar
i agree with Dennis, u prolly got a leak if the noise became more pronounced all of the sudden.
Old Apr 19, 2011 | 01:20 AM
killermax3's Avatar
thnx for the answers. tomorrow morning imma jack the car up and see if the bolts need to be tightened. Im hoping its just that...
Old Apr 19, 2011 | 10:50 AM
killermax3's Avatar
hmm ok so all the bolts are tight as can be. I couldn't find any leaks while under the car. Now i'm at a loss as to what could cause this
Old Apr 19, 2011 | 12:47 PM
maxxxdout's Avatar
i just had a similar issue and when i got under the car it wound up being my resonator. The thing had leaks around the base of the resonator pipe. So i had to cut it off completely and replace it with a piece of pipe..so now im straight piped from the cat all the way to the muffler.
Old Apr 19, 2011 | 12:55 PM
killermax3's Avatar
had no resonator to begin with. When I did my system it was 2.5 custom piping from the cat back no res. with a super street turbo muffler. did that first then a week later added on my warpspeed y pipe. This is really confusing. Could a bat cat be a likely cause?
Old Apr 19, 2011 | 01:15 PM
maxxxdout's Avatar
im not going to say yes or no to the bad cat. but the best way to find the leak would be to look under the car with it running.
Old Apr 19, 2011 | 01:23 PM
killermax3's Avatar
had the car up and running i visually checked for leaks and ran my hand thru multiple places to see if i can feel anything escaping anywhere. found nothing
Old Apr 20, 2011 | 10:02 AM
DennisMik's Avatar
If the car was just idling when you were looking for leaks, it could be easy to miss it. When the engine is revved up, there is more back pressure in the exhaust system. You would probably need a helper for this, but you can hold a rag over the tail pipe which will pressurize the exhaust system and make any leak more obvious. If you have a good exhaust system and you plug the tail pipe real good, the engine will die from too much back pressure.
Old Apr 21, 2011 | 06:18 PM
jfbalkcom's Avatar
this thread helped me with my problem, thank you
KabirUTA13
19
Oct 17, 2015 02:15 AM
05RLS2
Sep 27, 2015 09:24 PM
foodmanry
Sep 24, 2015 12:02 PM
lrb6805
Sep 17, 2015 04:49 PM
JoshG
Sep 5, 2015 10:10 PM
