what size sway bar bushings
Old Apr 17, 2011 | 02:04 PM
quique's Avatar
so i ordered es and moog bushings, ball joints, end links and es sway bar bushings. I found that the sway bar bushings do not fit my 99 SE they are the 20mm ones from ES has anyone had this problem and what size is it since this is what they list for the 99 max. thanks
Old Apr 17, 2011 | 05:47 PM
daze1984's Avatar
i just replaced mine with es bushings about a week ago, i have the same problem.
Old Apr 17, 2011 | 08:10 PM
hornepirate's Avatar
i cant remember what size es bushing i bought but i had to custom weld brackets for them to fit. ES doesnt make (as far as i found) oem replacement bushing for our car.
Old Apr 18, 2011 | 02:02 PM
quique's Avatar
well that sucks. they sell them like they are specifically for the maxima
Old Apr 18, 2011 | 05:16 PM
RA030726's Avatar
I'm nutty for Nissans
7-5118G
Fits like stock.
http://www.energysuspensionparts.com...?prod=7%2E5118
Old Apr 18, 2011 | 09:29 PM
quique's Avatar
those are the ones that i got but they didnt fit. i think they might be the wrong ones in the package because they dont look like the ones in the pic
Old Apr 18, 2011 | 11:38 PM
Originally Posted by JSutter
i didnt think es made OEM bushings for the max.
the stock brackets are small and kind of at an angle
Old Apr 19, 2011 | 01:32 PM
RA030726's Avatar
I have every ES bushing, they fit
Old Apr 19, 2011 | 04:33 PM
quique's Avatar
anyone else have any input here, not sure if i should order new ones
Old Apr 19, 2011 | 06:17 PM
speedvision's Avatar
Well, as far as input - I have just Installed (yesterday) Prothane Frame Mount Brackets & Bushings since I had a fubar Torn-Ripped Bracket. I measured them, and dry fitted them before installing and, I recall there was a 1 mm variance. Sure its for designed movement and room for grease. Anyways Yes on my 1998 max gxe I have a 20mm sway bar, with 20 mm bushings. Did you measure the bushings you have bought? have you measured your sway bar? It sounds You are right and have received the incorrect size bushing.
.02
Old Apr 19, 2011 | 06:30 PM
quique's Avatar
the bushing actually says on it that it is a 3/4 and i didnt measure the sway bar. But the picture on the site is different, and so was the bushings that i compared them to at autozone. im going to see what the vendor says and see if they send me a replacement, ill let you guys know how it goes.
Old Apr 20, 2011 | 01:35 PM
RA030726's Avatar
I just got a new set from Courtesy Nissan. This is what should be inside.
Part number stamped on the bushings is 5499.
Old Apr 20, 2011 | 04:16 PM
quique's Avatar
cool thanks. looks like i got the wrong one. mine are stamped 5299- 3/4
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
