Little annoying Ticking sound
ok first off its not the injectors its coming from the passenger side of the vehicle first i had a shop look at it they told me it was my tensioner ok fixed that now same issue not one shop could tell me at least 90% sure of what it could be they say maybe a lifter ticking or timing chain from what i can tell its not affecting the performance of the car just like a little nat that wont go away any ideas or another place to start replacing things?
I had an irritating ticking sound on mine. People on here said it is the injectors. But I have my valve covers off and checked valve lash. I had 6 intake valves that were not within spec.
You can try to pin point the ticking using a long screwdriver. Touch the tip of the screwdriver to a part of the engine, and touch the handle to your ear. Listen this way in several different areas to find where the sound is loudest.
Timing cover would probably be the chain, valve cover = lash, and if the sound is coming from the injectors, then that is normal.
ya im not sure its along with the injector ticking but sounds just like it but magnified how hard is it to put in a new timing chain and tensioner etc...
ive got 250k on it and its still running like a champ but i dont want to dump tons into it if i can just rebuild it for cheaper
omg a couple hundred bucks later and numerous shops stupid opinions i finally got rid of that little annoying ticking sound all along it was my power steering belt not the big major serpentine belt but the little one behind it i think it was about 250,000 miles overdue lol
the belt was literally down to like a 3 inch section that still had some belt left on it
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
