Using A/T Cooler for P/S on 5 spd swap car
Old May 6, 2011 | 05:49 PM
ajm8127's Avatar
I am in the middle of replacing my lower rad support and I was thinking; I had an auto that I swapped to a manual so I have an extra cooler on the bottom of my rad. I was thinking of plumbing my power steering system into this cooler. The lines are right there already all I need is some hose. The stock P/S cooler lines are a return to the tank, so it's low pressure. The cooler was originally filled with ATF, and that's what the P/S system uses as well.
What do you guys think?
Old May 6, 2011 | 07:13 PM
asand1's Avatar
Is this installed into the bottom tank or "separate". Might be too hot, unless PS runs hotter than the motor. Idk. Considering the factory cooler is mounted in front of everything else to be in the cold air, I think your proposed mod might be detrimental.
Old May 6, 2011 | 10:39 PM
FallenOne's Avatar
I don't. Although I'm in for someone more experienced.
I Will say, I can't see the PS pump needing cold fluid?
Old May 7, 2011 | 01:06 AM
aackshun's Avatar
This is news to me, I thought only 95-96s had PSF coolers.... With the extra lines running in front of the radiator, and I thought in 97 they kind of tee'd off those lines making them run a loop and bypassing that extra line that goes in front of the rad and back to the resevoir...
Old May 7, 2011 | 06:12 AM
ajm8127's Avatar
That's a good point. The cooler is integrated into the radiator. I think I should measure the temperature of the fluid after some spirited driving before determining that this is a good idea.
I don't think the power steering fluid needs to be cold, but if you can remove some heat from it, it would probably prolong the life to the power steering hydraulic components.
My 97 SE has a aluminum loop run in front of the radiator as a kind of power steering cooler. I've got a 99 GXE parts car that just has the rubber line looped back on the passenger side of the car where the aluminum loop on my 97 would connect. So I tihnk it depends on the trim level.
Old May 7, 2011 | 10:01 PM
FallenOne's Avatar
I don't think I've ever heard of a Power Steering Pump going bad on these cars but once every blue moon...
Old May 9, 2011 | 07:20 AM
njmaxseltd's Avatar
I don't think it would be a wise idea to run the p/s fluid through a 180 degree "cooling loop". There is no way that p/s fluid ever reaches those temps. I personally feel you'll actually be adding unwanted heat to the p/s system.
Old May 9, 2011 | 09:27 AM
asand1's Avatar
This was my thought also. I will check my lower tank and see what the temp. If it is the "cold" side it might be cool enough to be feaseable.
Old May 9, 2011 | 09:30 AM
demonics12's Avatar
power steering fluid doesnt reach the temperatures needed to use any type of real cooler.
the factory cooler resembles a hairpin in shape, thats all it is because thats all it needs.
Old May 9, 2011 | 09:37 AM
asand1's Avatar
Running autocross with a 97 rack (higher steering gear ratio), which many people do here, you might heat up the fluid enough to lose some performance, and OP has no cooler. Personally I would just buy a small remote tranny cooler and call it a day.
Ill put my temp gun in the glove box and collect some numbers.
Old May 9, 2011 | 09:40 AM
ajm8127's Avatar
I thought that as well. But the stock setup is for stock driving in a grocery-getter. If you were auto-Xing on a hot day, your power steering temps might get up there.
This was just something I considered while looking at my car with the bumper off.
Old May 9, 2011 | 09:43 AM
ajm8127's Avatar
You beat me to it.
This isn't exactly high on my to-do list and I wouldn't put the money towards a remote cooler. I was just trying to re-purpose an unused part.
Lakersallday24
Jun 16, 2019 01:35 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MikesChevelle
Aug 14, 2015 12:31 PM
Supragte
Aug 12, 2015 10:00 PM
09maxshawn11
Aug 9, 2015 01:13 PM
