I need help with changing inner cv axle tranny seal
Old May 7, 2011 | 06:13 PM
saylee's Avatar
Wsup guys, ive never changed a tranny seal before
so I wanted to ask how to go about doing this. I just wanted to ask how to pull the seal out, I think it's personally just pulling the seal out the differntial then putting new one in but I wanted to check with any member who has done the job before. Thanks and God Bless guys..
Old May 8, 2011 | 01:36 AM
ef9's Avatar
ef9
I used a regular seal puller. It looks like a prybar with a hook on the end.
When I installed the new seal, I put a thin film of grease on the mating surface of the seal (to the transmission) then gently tapped it in with a hammer and 3/8" extension.
I carefully tapped around and around with the 3/8" extension.
Old May 8, 2011 | 04:59 AM
max ride 41's Avatar
yeah, be careful doing that. you dont want to seat the seal in bent or crooked.
Old May 8, 2011 | 07:08 AM
luke95gxe's Avatar
yeah autozone sells seal pullers for about 10 bucks i put grease around the seal like stated above but i use a socket thats the same size diameter of the seal and tap that in with a hammer that way the seal seats flush
Old May 8, 2011 | 08:04 AM
VisciousMo's Avatar
Seal puller from auto zone like the posters above. Be very careful or you can break the seal fairly easily.
Old May 8, 2011 | 10:30 AM
99greddymax's Avatar
i used a Flathead screw driver to pry the old seal out, then tapped the new one in place.
Old May 19, 2011 | 08:34 AM
99zx2's Avatar
if you do this, put some electrical tape on the tip. you don't want to scour the mating surface.
boomerbrian
Oct 31, 2018 10:25 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
pjgreek
Sep 9, 2015 09:30 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
pktaske
Sep 4, 2015 08:40 AM
