00vi odd question....
Old May 8, 2011 | 03:52 PM
clint240sx's Avatar
I want to start my setup today, finish it tomorrow. But the ONLY thing i am missing is the RPM swith. I will order one either tonight or tomorrow. Now my odd and possibly dumb question is, can I run the 00vi setup without the rpm switch?? Will this cause issues? I know I basically won't make power top end, but the kit would be installed, and that's exactly what I want to accomplish.
So is this possible or do I just sound like a noob? lol
BTW, I plan to use the 4th gen LIM without the EGR, and 4th gen IACV.
Old May 8, 2011 | 03:57 PM
essential1's Avatar
My axles cry for mercy...
Just tie the VIAS assembly open for now. Or just remove it completely.
Old May 8, 2011 | 04:00 PM
Product_Of_Korea's Avatar
yes you can run w\o rpm switch. What are you planing for the egr delete?
If you want to go a cheap route you can use a toggle switch and do it manually.
Old May 8, 2011 | 04:02 PM
clint240sx's Avatar
This sounds unprepared, but i'm not sure...lol I'll call my shop in the morning and see what they recommend. I have all day tomorrow off. Any input for it?
I don't mind using it. Just not sure what would suit me better in all honesty.
Old May 8, 2011 | 04:07 PM
silencecalls's Avatar
I ran my 00vie without an RPM switch for 3 months. it's basically just like not having an 00vi as you only get single runner all the way. For EGR, just put in a block off plate on the the tube and that's it. That won't case you to throw a code. Also check your VIAS valve to make sure it's not broken, it will save you some time in the future.
4th Gen IACV is also the way to go. Once again, won't cause codes. =)
Old May 8, 2011 | 04:08 PM
clint240sx's Avatar
Thanks for all your input guys! I'll be getting started, and taking pics of my process, and post on here if i need help!
Old May 8, 2011 | 04:11 PM
to add to that you will need to have the egr temp probe hooked up to not throw a code.
Old May 8, 2011 | 05:39 PM
jholley's Avatar
Since you'll have to use the DE injectors with the 4th gen LIM it won't hurt your air/ fuel mixture. I'll be installing the 00VI with DEK injectors so I'm waiting until I find a VAFC II. I don't want to run a rich mixture on the CAT I recently installed.
Old May 8, 2011 | 05:59 PM
schmellyfart's Avatar
FWIW I do throw a an EGR code (0302: hi/low flow) from time to time. Both the EGR temp probe and solenoid are still hooked up, and EGR equipment removed.
Old May 8, 2011 | 08:32 PM
clint240sx's Avatar
update, pics from phone
Sorry, pics are crap. But for those who have done it...how does my engine look in general? Anything look out of place? I've never dug that deep into my engine before should be getting the holes drilled tomorrow and then installing the 00vi . Any tips for how I am doing? this took me 2 hours overall. Can I replace the valve cover before taking out the LIM?
Old May 8, 2011 | 08:36 PM
MaximaSpd85's Avatar
everything looks ok to me. yes, you can replace the valve cover now, its not in the way of the lim. make sure not to drop anything down any of those 'holes' lol
Old May 8, 2011 | 08:38 PM
clint240sx's Avatar
Haha, no kidding!
I got a good look at the spark plugs...and the area of course, all the oil was were is should be....no leaks I noticed....makes me feel that much better when I'm sitting at 172,xxx miles!
Old May 8, 2011 | 08:40 PM
clint240sx's Avatar
Man, I wish i had 350z cams as well...could have just thrown them in with the adapter...haha
Old May 8, 2011 | 08:49 PM
haha, if only it were that easy we'd all have cams. youre looking at an additional many, many hours of labor to swap cams out.
Old May 8, 2011 | 09:27 PM
clint240sx's Avatar
lol i know!
well idk if i removed everything slow or not...but it took me 3 and 1/2 hours to get to that point.
Did I move fast or slow?
Old May 8, 2011 | 09:43 PM
Not to bad for your first time.
And yeah cam job with motor in car is not so fun either.
BTW what valve cover are you using?
Old May 8, 2011 | 10:00 PM
Took me about 6 hours to get to that point my first time around. Yes, notice I said first.
After all was put in I discovered that I leaked oil from the rear valve cover like crazy because I did not install enough washers. My bolts for some reason were longer then they should have been and the cover was not on tight enough. So I had to take it off two more times.
Old May 9, 2011 | 07:01 AM
clint240sx's Avatar
The valve cover is from a 2000 Maxima. It was not the one in the picture above. I'll post more pics today now that I have more daylight!
Old May 9, 2011 | 10:39 AM
ProW649's Avatar
good luck w/ the swap bro...
Old May 9, 2011 | 03:34 PM
Just making sure you have the right VC or a modified one before you throw on your upper
Old May 26, 2011 | 03:09 PM
clint240sx's Avatar
Here is the ALMOST finished project...sorry it took a while to post up pics, I got lazy..haha Just need the RPM switch now.
Enjoy!
Old May 26, 2011 | 09:12 PM
FallenOne's Avatar
You should have painted that manifold. Its... White?
Old May 27, 2011 | 06:37 PM
clint240sx's Avatar
Not too sure how it got that color, got it that way. I left it like that because it reminds me of the stock one. Kinda weird I know.
KabirUTA13
19
Oct 17, 2015 02:15 AM
lrb6805
Sep 30, 2015 08:12 AM
05RLS2
Sep 27, 2015 09:24 PM
foodmanry
Sep 24, 2015 12:02 PM
lrb6805
Sep 17, 2015 04:49 PM
