what is this connection?
Old May 12, 2011 | 11:47 AM
95nissmax's Avatar
so i was snooping through my cars engine and found this connection, what is it and where does it go to? please help
it is located neat the air intake
Old May 12, 2011 | 12:32 PM
silencecalls's Avatar
It goes into the stock snorkel, when it was there.
What it's for I'm not sure. Lemme dig up the FSM and take a look.
FallenOne's Avatar
Lawlz. The connection for that is Right below where its seated in the last picture IIRC.
Old May 12, 2011 | 12:33 PM
luke95gxe's Avatar
could be the map sensor connection or the air temp sensor
Old May 12, 2011 | 12:35 PM
VQ'rInWLA's Avatar
Yeah Im thinking IAT sensor.
Old May 12, 2011 | 02:59 PM
RA030726's Avatar
I'm nutty for Nissans
If its was either sensor youd have a CEL.
Old May 13, 2011 | 06:08 AM
njmaxseltd's Avatar
Does the check engine light even work on this vehicle?
Old May 13, 2011 | 06:27 AM
jholley's Avatar
That looks like the IAT sensor connector which is mounted on the air duct.
The MAP sensor has black wires.
Old May 13, 2011 | 06:49 AM
ajm8127's Avatar
Definitely try to read your codes, that could narrow it down significantly. Also, it looks like this connector branches off from the main engine harness that runs across the top of the engine and the wires to it are red/yellow and orange/blue. Is this correct? Could you take a picture of where it branches off? One up close for detail and one farther away for context?
The closet I can find is the EGRC solenoid (F24). Though has a red/yellow wire and a blue/black one according to the 95 EC section. I cannot find any connections to the ECU use a orange/blue wire.
On a '95, the IAT is mounted in the side of the top half of the air box, not the ducting like other years.
It may also be possible that connector is for some EVAP related equipment that a 95 California model has but a normal 95 USDM model doesn't have. Which means that a 95 FED spec ECU would throw no code. That is assuming they use the same harness.
Old May 13, 2011 | 07:55 AM
luke95gxe's Avatar
just went and look at my iat sensor wire colors mine are blue and black im a 95 i couldnt find a connector at all with them wire colors under the hood in that area
Old May 13, 2011 | 05:17 PM
RA030726's Avatar
Did someone replace the knock sensor harness and leave the old one in place?
Old May 13, 2011 | 06:02 PM
Maxima_Joe's Avatar
4th Gen Parts King
That appears to be the connector for the map/baro solenoid.
Old May 13, 2011 | 06:12 PM
ajm8127's Avatar
From what I can tell, the MAP/BARO solenoid didn't come about until 96 where it uses a orange/yellow wire.
Old May 13, 2011 | 06:46 PM
Maxima_Joe's Avatar
4th Gen Parts King
Cali spec 95's have a map/baro solenoid. You can tell his car is a cali spec based on the one pic showing an evap canister purge control valve
Old May 16, 2011 | 05:50 AM
ajm8127's Avatar
I can't seem to find any mention of the MAP/BARO solenoid in the 1995 FSM. There is no connection to pin 16 (MAP/BARO pin of other years) of the ECM according to the "ECM Terminals and Reference Values" section, and it is not in the "Circuit Diagram" either.
Then again, the FSM has been known to contain errors. It seems like the production line and the FSM are not always in sync. For instance, I took an engine from a '99 and it uses letters to denote the grade of the crankshaft and main journals. According to the FSM, this practice did not start until '00.
Old May 16, 2011 | 07:24 AM
max ride 41's Avatar
if the cars running ok, who cares. i have a 95 and dont have that plug.
Old May 16, 2011 | 05:53 PM
styliztik's Avatar
I went out to my car to see. it's a 98 non cali spec. I looked for connections in that area with a red/yellow/grey stripe. I found two.
I circled the two connections I found. the blue arrow denotes front of car.
Old May 27, 2011 | 07:42 PM
Trini Boom's Avatar
If that harness has a brown connector, then its the MAP/BARO solenoid harness.
Old May 28, 2011 | 11:28 AM
jumpsteady66's Avatar
Its the air temp sensor i just had to replace my
Old May 28, 2011 | 12:02 PM
damn dude, clean underneath the hood allready
Old May 28, 2011 | 03:28 PM
Trini Boom's Avatar
Trust me, I have seen worse...that's in good condition
Old May 28, 2011 | 07:26 PM
Swazey's Avatar
the green one is for the knock sensor. ill have to double check the other tomorrow
Old May 30, 2011 | 09:38 PM
Trini Boom's Avatar
zmcneely13
Sep 26, 2015 02:26 PM
