Rotor / Bleeding
Rotor / Bleeding
1. What is the hub nut size to remove the r.r. rotor, the big one with the cotter pin in front of it?
2. If you have only opened the right rear brake line, do you need to bleed all 4 lines or just the one you opened? (seems to be a controversy on this point)
you dont need to remove the hub nut to remove the rotor. just take off the caliper and it comes off. and what do you mean with only opening? if you disconnected the hose and fluid leaked out then yes the whole system has to be bleeded.
Just ask someone to pump the pedal for you. I'll bet the first person you ask will not turn you down.
you could run back and forth but anyone can pump the pedal for you. or you can buy those speed bleeders from local parts store.
Apr 16, 2020 05:15 AM
