knock sensor
knock sensor
Well i just changed my knock sensor because my car was running like crap
http://forums.maxima.org/picture.php...ictureid=27022
http://forums.maxima.org/picture.php...ictureid=27023
well that didnt help anything i also cleaned the TB and IAC valve, changed spark plugs, im kinda leaning towards its a fuel problem maybe dirty injectors or something, what do yallz think?, a friend said maybe TPS needs to be changed i do get a smell of fuel sometimes
change its harness. describe what feels like crap about the car. many things you could do as a tune up
change plugs, fuel filter, air filter, drop a can of bg 44k fuel system cleaner, sea foam, clean TB & MAF
I'm getting Speed Sensor and KS codes also - bought both sensors - replaced VSS but speedometer (which also affects odo) still working intermittently.
KS is sitting new in a box - I read about the easier way to do it but don't feel I can tackle the job. Anyone around SouthFL that can help me replace my KS (I believe it's bank 1)?
Did you have other codes. A bad KS itslef WILL NOT set the light on. Other codes will trigger a bogus KS code. Bad KS will cause loss of power and mileage, but will not cause poor running (missfire).
the only code i got was a p0325, so i changed the KS, i have read that i need to replace the sub-harness, the symptoms i get is when i put it in gear(manual) and accelerate i get this hesitation feel then it finally accelerates good, i did notice a drop in my gas mileage, i have done TB, IAC, MAF cleaning, replaced spark plugs to iridiums, i do get a faint smell of gas sometimes, i do not have any timing data, i should take is somewhere and see what the timing is, when i first got the car in february it did run clean, could it be that i had put 87 octane gas and now went back to 91? i love my maxima, i appreciate all the comments as well thanks guys, i appreciate all the feedback as possible to get my ride back up and running like normal again
i maybe need to put some seafoam, i did clean the air filter and replaced the fuel filter, something i just remembered my cuzin told me when i bought the car that the gas tank needs some sort of seal or gasket because it leaks if i fill the tank up and park it at an incline
Last edited by 95nissmax; Jun 11, 2011 at 03:54 PM. Reason: had to add some more info
for that scent of gas when you fill it up, check the gas filler tube that runs from the gas inlet port on the side of the car down to the gas tank. My '98 max exhibited the same symptom and when the mechanic pulled off the cover for the gas filler tube (located in the left rear wheel well) we foudn that the tube was completely rusted through. Cost $8 to replace and the smell went away completely.
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
That knock sensor overheated?? Amazing.... How many miles on this car??
