KS Ghost code P0325
Old Jun 14, 2011 | 03:50 PM
Boothers96's Avatar
KS Ghost code P0325
Ooooook so you guys have helped lots so far and this car seems to keep coming up with fun ways to test me....i should really just start a build thread.
Anywho...Lately the car has been giving me the pleasure of bucking/stuttering only under load and only less than about 2500 rpms....since after doing research and cleaning my MAF, TB and K&N, im almost 100% sure its gonna b coil packs...ordered, theyre on their way....ok my question starts with this. I pulled the P0325 code and it said knock sensor. bought one off ebay $25 shipped took out old (looked pretty good but didnt test since i have new one) and installed new one. 2 days pass im getting no codes for the stuttering or anything but the dang KS code comes back no matter how much i clear it.....is this caused by the bucking/stuttering? Ive read conflicting things about misfires triggering a KS code.....
Thanks again for all your help.
Steve
Old Jun 14, 2011 | 06:10 PM
asand1's Avatar
Is it the only code coming up?
Old Jun 14, 2011 | 07:20 PM
Boothers96's Avatar
yes only code.
Old Jun 14, 2011 | 07:34 PM
95nissmax's Avatar
@boothers96 well dude nice too meet another brotha who is having the same problems as me, i scanned my car to see what codes it would throw at me because i was having the same issues as you, it pulled the KS code, i replaced it got it off ebay as well, then i tried clearing the code only to find out it keeps coming back so it leaves me scratching me head, then today i buy a brand new sub-harness from the nissan dealership here it came out to like 50 bux replaced it and guess what?? same problem occurs with the bucking and stuttering, so now im believing it just might be my coil packs going bad,
check out the pics of my KS
Old Jun 14, 2011 | 07:42 PM
Boothers96's Avatar
well shoot if u want to wait a few days for my packs to get here, ill let ya know if thats the deal.....
i bought these:
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
ill also b pulling plugs tomorrow but idk y it would be those, they're NGK Plats w only 20,000 mi on them. well see tho
Old Jun 14, 2011 | 09:36 PM
95nissmax's Avatar
I replaced my plugs with ngk iridiums, ill wait dude, that is my next move replacing the packs
Old Jun 14, 2011 | 10:14 PM
cartman854's Avatar
Just pull each pack and look at it. Also pull it while the car and see if it males the car run worse. If it doesn't it was already failing. Do one at a time.
Old Jun 14, 2011 | 10:15 PM
95nissmax's Avatar
Good start cartman doing that tomorrow
Old Jun 14, 2011 | 11:16 PM
Boothers96's Avatar
Wont help....ive inspected all coils non show VISUAL damage....and it wont help to do it with the car running because it idles like a dream...no shakes or misses...this is strictly ONLY with a load and only from ~700-2500 rpms. So at idle with no load the bad coil/coils can still function under minimal resistance....but when more is demanded of it, it stutters under heavy resistance.....Essentially every coil pack i would pull at idle makes it run crappy.....
Thanks for your help tho cartman.....
Old Jun 15, 2011 | 10:21 AM
99zx2's Avatar
you know you can test coils for resistance, right? as well as knock sensor. there is a big chance the one you got from ebay is dead. test the old one, resistance should be around 550k ohms.
Old Jun 15, 2011 | 11:33 AM
cashoit's Avatar
prolly got dead KS on arrival.
Sputtering will not cause bad KS nor will bad KS cause a sputtering. The sputtering is prolly a result of a bad MAF. u can try coils but it sounds more like bad MAf to me. Cleaning it dont always help especially if its already shot.
Old Jun 15, 2011 | 01:21 PM
Remminator's Avatar
Use one 470K across the connector, i have a 3.5 swap and this resistor killed that code for me. Only thing is, you won't have a functioning KS, but then again, wgaf.
Old Jun 15, 2011 | 03:12 PM
Boothers96's Avatar
ok...so KS tested at 546k-550k ohms...so thats good...the source has roughly 3.3-3.5 volts. so its getting power and functioning....im testing CP next but ive read that CPs will sometimes test good even if theyre on their way out?
Old Jun 15, 2011 | 05:05 PM
LONDART's Avatar
does anyone have a pic of the other end of the ks connector
I have a 95 and when i did my a/t swap i used a flashlight and could not find the ks to replace it,1 of th p/o's did an engine swap and i dont know if maybe they just left this part off
hope to find the other end and trace the wires to it if its still there
Old Jun 15, 2011 | 07:20 PM
Trini Boom's Avatar
I currently have this same exact issue. Bought the KS from a member i the classified which was an OEM one never used but had it sitting for some time and the code is still there. Don't want to waste money on the harness if it doesn't cure the problem. My next thing is to somehow scuff the surface where the KS sits by squeezing my hand in there. Once reseated, hopefully the code is gone for good.
Old Jun 17, 2011 | 01:17 PM
95nissmax's Avatar
I bought the ks brand new replaced it and the code was still there then the next day went to nissan purchased the new sub harness and guess what code was still there even though I tried erasing it so hmmmm what can it be
Old Jun 20, 2011 | 09:55 PM
Boothers96's Avatar
Checked plugs today. They look pretty good for NGK Plats w/ 20k miles on em.
theyre in order
Cyl
1 3 5
2 4 6
Also cleaned the coil packs i have as per the thread on here i found about cleaning hanshin CPs....didnt help...car seems a tad more responsive, could b placebo effect, but stutter still remains...hopefully ill get the new CPs in the mail soon, theyre coming from hong kong....well see.
Old Jun 20, 2011 | 11:01 PM
95nissmax's Avatar
How do u clean the CP? Id try anything to get my maxima back to normal could my sputtering be because I've put 87 octane?
Old Jun 21, 2011 | 05:04 PM
asand1's Avatar
Do a compression test. Could be burned exhaust valve.
Old Jun 22, 2011 | 05:28 PM
Trini Boom's Avatar
Just to update you guys, after constant erasing of the KS code, I was able to clear it by disconnecting the harness, clear the code and the reconnect the harness. After driving around now for over 100 miles, I got another ghost code P0400...bummer.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
