Seafoam helped me pass CA emissions!
Old Jun 15, 2011 | 10:39 AM
triax37's Avatar
I know there have been a ton of Seafoam pro/con threads, but none discussed emissions in detail, and I wanted to pass along this information for those that may be struggling to pass CA's tough emissions.
Car: 1999 Maxima ES, 5 speed, Y-pipe, 125k miles, high-flow catalytic converter, generally good condition, running Amsoil oil since 60k.
After failing the CA emissions several times (mostly due to high NOx), and trying a variety of things to fix the problem (spark plugs, air/oil/fuel filter, EGR cleaning, new coolant/thermostat, switching back to the OEM cat, praying), I was running out of options. During the last failed test, the SMOG guy mentioned that Seafoam in the vacuum line may help reduce some deposit buildup and lead to better ignition, which would make the engine run cooler and reduce NOx. So I purchased a $10 bottle from him, went out to an unpopulated area, and did the sip/slurp method and watched smoke pour out of the pipe. 30+ minutes later, I went back to the SMOG shop. And PASSED! Numbers below:
HC_______Pass___Before__After
-15 mph___55_____77_____30
-25 mpg___39_____39_____21
CO_______Pass___Before__After
-15 mpg___0.50___0.17____0.09
-25 mpg___0.48___0.07____0.05
NO_______Pass___Before__After
-15 mpg___437____715____297
-25 mpg___724____342____383
Literally, the only difference was adding Seafoam in the vacuum line. The car was fully warmed up on both occasions. I was almost shocked. Anyway, I hope this is helpful to someone trying to get their old, trusted Maxima through a tough CA emissions test. Good luck!
Old Jun 15, 2011 | 11:23 AM
cashoit's Avatar
keep ya car clean...aint nothing amazing bout that.
Emissions testing sucks
Old Jun 15, 2011 | 11:35 AM
Rods03Max619's Avatar
Yes sir especially in Cali....
Old Jun 15, 2011 | 11:52 AM
FallenOne's Avatar
Oh, and Chevron Techron would have done such a better job.
Old Jun 15, 2011 | 11:55 AM
cashoit's Avatar
dont knock it till u try it
3 maxes...a bottle every oil change..never any emission issues over here
Old Jun 26, 2011 | 06:51 PM
98maxima76's Avatar
Definetly made mine run smoother...
Old Jun 26, 2011 | 07:23 PM
Goomz's Avatar
damn those number contrasts are HUGE
Old Jun 27, 2011 | 08:50 PM
Hotsuma's Avatar
I agree. I may try that this weekend. Off to find a tutorial on what to do.
Old Jun 27, 2011 | 09:45 PM
QT1 5MT AE's Avatar
Gram Lights addict
BG 44k >*
Old Jun 27, 2011 | 11:27 PM
VQ'rInWLA's Avatar
Pricey compared to SF. Is it that much more effective?
Old Jun 28, 2011 | 04:34 PM
southerng's Avatar
i have go to finally try this once i get a new car lol
Old Jun 28, 2011 | 04:39 PM
loslobos's Avatar
I hate emissions testing
follyburr
Detailing
Jun 13, 2016 02:06 PM
JoshG
Sep 5, 2015 10:10 PM
TheMafia
Sep 4, 2015 08:26 AM
