Timing case is off, what a pain
Old Jun 17, 2011 | 02:13 PM
AJE's Avatar
AJE
Anyone else on here done the timing case orings with the engine still in the car? The stud for the engine mount doesn't have enough clearance between the fender to get the inner case off. The only way I got it was to remove the water pump (got me about a 1/2" closer) and then rotate the inner cover almost upside down and then it just barely came free.
With only the right side mount off, I tried jacking the engine up as high as it would go and lowering it all the way, but that stud is really in the way. Is there anyway to take that sucker off? I'm sure I can get the cover back on but not without messing up the RTV. Maybe I will have to RTV some of it after getting it back over the stud?
Any advice appreciated!
Thanks, AJE
Old Jun 17, 2011 | 04:55 PM
AJE's Avatar
AJE
Here is the stud:
And yes, I know the CV boot is torn
Old Jun 17, 2011 | 08:22 PM
SuperSlow_max's Avatar
pull the engine out
Old Jun 17, 2011 | 08:41 PM
AJE's Avatar
AJE
Thanks, I'll remember that "next time."
Old Jun 18, 2011 | 09:31 AM
Remminator's Avatar
I hate to say it, but it will be much easier to pull the engine, and you will have a much better view and space to work. It's not that hard to pull the engine.
P.S. you can take out that stud by clamping a vice grips on there really freaking tight and twisting it out. I had same problem, out of the car.
Old Jun 18, 2011 | 11:40 AM
asand1's Avatar
Use 2 nuts jammed together and put a boxend wrench on the inside nut to unscrew the stud. When replacing the cover, place the stud in the cover with rtv holding it in place.
Old Jun 18, 2011 | 12:28 PM
doctaroofy's Avatar
Yes, I've been trying to figure this out too.
Old Jun 19, 2011 | 09:40 PM
AJE's Avatar
AJE
Thanks for the replies. Ended up tying ropes to the p/s and a/c lines to hold them back as far as possible, then after lots of practice and perfecting just the right angles I was able to get it in and over the stud without smearing the RTV. Lets hope that RTV does the trick, I'm not going to want to do this job again anytime soon.
Another note for anyone who comes across this thread, if you happen to bump the pin holding the spring and guide on the front cam chain tensioner and they go flying PUT THEM BACK IN BEFORE PUTTING THE REAR COVER ON. Once the cover is on there isn't enough clearance to get them back in, found this out the hard way...cost me a few precious hours to redo, way too much RTV to clean off and reapply, not to mention the 25 screws to remove clean and re-torque. OUCH
Old Jun 20, 2011 | 12:58 PM
DBear's Avatar
AJE--
Why did you pull it, to fix an oil leak? If yes, where were you getting the drips? I've been getting a leak that seems to be coming from around the oil pump, and I fear I'm in for the same job.
Old Jun 21, 2011 | 12:28 AM
AJE's Avatar
AJE
Yeah, hoping to fix an oil leak. I was getting the worst drips from near the oil filter, which as high up as I could follow it up looked to be driping from the end bolt of the exhaust manifold. I also had a ton of oil covering my alternator and ac compressor on the front. I have read on here about the orings between the rear timing case and the block, but after getting in there it looked more like the RTV seals around the bottom of the cams.
The old orings were flat compared to the nice new round ones, so they could definately have been leaking as well but the most worst was definately coming from right above the water pump where it seals below the cam.
Old Jun 21, 2011 | 12:28 PM
DBear's Avatar
Let us know if it that solves the leak.
Old Jun 27, 2011 | 11:45 PM
AJE's Avatar
AJE
Yes, I am happy to say the oil leak is fixed.
Old Jun 28, 2011 | 12:26 PM
DBear's Avatar
Glad to hear it. How long did it take you?
Old Jun 28, 2011 | 01:27 PM
AJE's Avatar
AJE
I hate to admit, but probably ~40 hours? I hit a few snags that ate up lots of time, but I could probably do it again in half that. Learned a lot about my car, that is for sure.
Old Jun 29, 2011 | 12:36 PM
DBear's Avatar
Ouch. But I know the feeling. It took me about 2 hours to figure out how to replace the PCV valve on my Durango. Now I could do it in less than 10 moinutes.
MattWithTheMaxima
Jun 30, 2017 01:06 PM
Finkle
Sep 27, 2015 09:53 PM
tnewbs
Aug 28, 2015 10:15 AM
FlaMark
25
t6378tp
Aug 24, 2015 07:03 AM
